Insulation
Insulation
Postby cincin » Mon May 05, 2008 9:35 pm
I hope this is not obvious, but I haven't seen much about insulating TD's. Are they? Is there a need for heaters? I've seen TD's with air conditioners and roof vents and fans, but not many heaters. Can someone address this for me? One thing I don't like about camping in a tent, I seem to always be cold.
Thanks,
Curious Cindy :oops:
cincin
Postby starleen2 » Mon May 05, 2008 10:36 pm
Welcome aboard – it is a matter of personal preference and geography. I carry an air conditioner in the summer (Hot in Texas) and heater in winter. Our camper is insulated with foam insulation mainly against the Texas heat. I must confess that we have used the heater very little and are considering an electric blanket instead.
starleen2
5th Teardrop Club
Postby john » Mon May 05, 2008 11:01 pm
I insulated as well. I live in NC. and find it useful in the southeast in general.
I use the A/C all the time in the spring, summer and fall. If it is not below 50 we use the A/C. Body heat is a killer.
I also have a heater. It is a 120v electric wall heater that we only use to warm up the tear before we hop in. We usually turn it off as soon as we are in.
The best thing about the insulation is that it keeps the inside of the walls from sweating.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby zukamini » Mon May 05, 2008 11:20 pm
We have foam board insulation in the walls, floor and roof in our teardrop, I picked up a small 12 volt ,300 watt car warmer and installed it under the rear storage area. on a late october fishing trip in Jasper, we woke up to a inch of snow on the ground and a temp. around 30 degrees. we only turned the heater on after we made breakfast and ate inside.
zukamini
Postby ARKPAT » Tue May 06, 2008 12:49 am
Wow mine is made out of insulation clad in steel sheets! Even have the Fiberglass panels in the background in the photo laying on the floor of the trailer with the strap around them.
8) :lol:
I also wanted to make the trailer a FOUR SEASON type trailer. 8)
Pat
ARKPAT
Images: 77
Good to know
Postby cincin » Tue May 06, 2008 8:17 am
Okay, great to know. Now I feel better. On the northwest coast I would use the heater a lot and keeping the inside from sweating is of course a plus.
Thank you always for being there, giving me good answers and options too. I love it.
Thanks,
Cindy
cincin
Postby Dee Bee » Tue May 06, 2008 5:39 pm
It will keep it cooler in Summer, warmer in Fall and dryer -preventing most if not all condensation inside...
Dee Bee
http://www.nfdc.net/home/cbdb/Teardrop.htm
Grace happens...
Dee Bee
Images: 55
Postby alffink » Tue May 06, 2008 5:59 pm
I have been building a Cubby and Kevin H. recomended the insulating panels
Was easy to do during the build, since Ilike the desert it works both in keeping it cool or adding to the warmth, secondary advantage, yesterday there was a poll about camping in your driveway or back yard, the fully insulated tear is is nearly sound proof...great for the afternoon nap.
alffink
Images: 37
