calumet wrote:Thanks for all the replies!
Is a sub floor only for attaching sides if it is not needed for clearance or insulation? If building inside the wheels it seems it would be lighter, easier, cheaper and make for a lower profile TD to bolt the plywood directly to the frame and then the sides to the frame. Is this a common design?
