Masonite for roofing material?
Postby Sparksalot » Sat Jul 19, 2008 7:25 am
The original Trailer for Two used this stuff. Has anyone done so recently?
It seems a shame to spend $20+ for sheets of 1/8" birch never to be seen again plywood when the masonite can be had for lass than half that.
Sparksalot
Images: 687
Postby halfdome, Danny » Sat Jul 19, 2008 10:14 am
The roof of any structure is there to protect the whole structure from the weather. Why cheap out with basically glued sawdust when for a few dollars more plywood will give outstanding protection if properly installed. The roof is part of the structure and plywood is more structurally sound than Masonite. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby madjack » Sat Jul 19, 2008 12:32 pm
Sparky, I know a lot of the originals used it but I have the same concerns as Danny and personally would prefer ply...BUT, one of the nice things about building it yourself is that you are building it yourself...
Postby satch » Sat Jul 19, 2008 12:43 pm
If you do go that route, make sure it is sealed good, any water penetration turn that stuff into mush 8)
If it itches. scratch it
Rick
satch
Images: 63
Postby Sparksalot » Sat Jul 19, 2008 3:11 pm
Thanks for the inputs folks. I have been considering back and forth, but wanted to hear some other ideas too. :thinking:
Sparksalot
Images: 687
Postby Gerdo » Sat Jul 19, 2008 5:18 pm
I would not use Masonite on a TD. As already said, it will turn into wet dog food if wet. I wonder if the formula has changed over the last 60 years. I used moisture resistant luan.
Gerdo
Images: 156
Postby 2bits » Sat Jul 19, 2008 5:44 pm
OK how about Orange box Luan as a step up from masonite, but a step down from the $20 birch? Any objections? I was thinking of this myself since this step is coming up soon. I am planning to seal all joints with epoxy.
Thomas
2bits
2bit Member
Postby Sparksalot » Sat Jul 19, 2008 5:54 pm
2bits wrote:OK how about Orange box Luan as a step up from masonite, but a step down from the $20 birch? Any objections? I was thinking of this myself since this step is coming up soon. I am planning to seal all joints with epoxy.
I've read elsewhere here really recently about 1/4" orange box luan cracking as it is bent around the radius.
I JUST finished putting the ceiling in. Feeling the tension in that forward portion made up my mind for me. I'm gonna do the birch.
Sparksalot
Images: 687
Postby tinksdad » Sat Jul 19, 2008 6:09 pm
Orange Box 5mm luan is only $12 a sheet here. I'm going to try boiling one sheet (as suggested in a different thread here) and using straps to pre-form it to the contour before anchoring it down permanently after it dries. If it works, that's what I'm going to use. if not, I'm only out $12.
tinksdad
Images: 155
Postby doug hodder » Sat Jul 19, 2008 8:14 pm
If'n it were me...I'd avoid the box store luan....the core has all sorts of crap in it, knots, voids etc and moisture content can be really high, causing it to do amazing things when it dries out completely, it's cheap for a reason....When it cracks, your nice smooth profile then has a kink in it. Not a real problem if you are planning on skinning in aluminum, but I did a painted one and it required a bunch of work to hide the crack. Quality also might be determined by where you live in the country. I'll never use it again except for a template, just what I experienced with it. You can make up for the price difference in other areas. Doug
Postby mikeschn » Sat Jul 19, 2008 8:18 pm
I'll second that Doug. I lost several weeks worth of work, and hundreds of dollars using luan, that twisted up really bad in the warm summer heat.
Postby Sparksalot » Sat Jul 19, 2008 8:48 pm
Interesting info on the luan. It really sounds like something to avoid.
Sparksalot
Images: 687
Postby john » Sun Jul 20, 2008 1:15 am
I used hard board on my TD. Flexible cheap heavy stuff, but it has to stay dry. I painted it first with some kills and good exterior paint then covered it with aluminum.
no leaks please :rainy: :rainy:
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby davel » Sun Jul 20, 2008 6:56 am
I have to agree with everything in this thread. However we used masonite on the entire Bluebonnet tear. The only thing I would have done different is what has already been voiced, I would have made sure it was well sealed from the weather before it was ever taken out of the garage.
After 4 1/2 years and over 16,000 miles the Bluebonnet is showing signs of wear. We are going to clean it up and epoxy it and I think it will keep it going for a long time to come.
davel
Images: 32
Postby GPW » Sun Jul 20, 2008 8:01 am
I'd rather use good Masonite than cheap ply...you're gonna' seal the heck out of it anyway, we all do...
