So to fix it I did this. The area was about 2"x4". I cut a letter H into the delam, and very carefully lifted it up with a screwdriver. Then I mixed some clear epoxy and with a small brush covered as much area as I could between the lams. I pushed the pieces back down, covered them with wax paper, laid a board on top and clamped the heck out of it. Hopefully this will work to make it lay flat, and then I will cover it wioth more epoxy, and resand until smooth. I'll let you know how it turns out......
