More Damage......
More Damage......
Postby Micro469 » Tue Sep 02, 2008 8:57 pm
Over the weekend I sanded the whole dang tear. I reepoxied all the natural wood and painted the trim. I didn't cover it because the trim was still tacky. Today, I resanded the epoxy so that I could put on the varnish and when I got to the roof, a section of my birch ply... not chinaply, had delaminated, and bubbled. This was near the fantastic fan, so I have to assume the fan leaked and water got into the ply. I probably said a few words you guys have never heard before.
So to fix it I did this. The area was about 2"x4". I cut a letter H into the delam, and very carefully lifted it up with a screwdriver. Then I mixed some clear epoxy and with a small brush covered as much area as I could between the lams. I pushed the pieces back down, covered them with wax paper, laid a board on top and clamped the heck out of it. Hopefully this will work to make it lay flat, and then I will cover it wioth more epoxy, and resand until smooth. I'll let you know how it turns out...... :?
John
Micro469
Images: 382
Re: More Damage......
Postby swissarmygirl » Tue Sep 02, 2008 9:00 pm
Micro469 wrote:Over the weekend I sanded the whole dang tear. I reepoxied all the natural wood and painted the trim. I didn't cover it because the trim was still tacky. Today, I resanded the epoxy so that I could put on the varnish and when I got to the roof, a section of my birch ply... not chinaply, had delaminated, and bubbled. This was near the fantastic fan, so I have to assume the fan leaked and water got into the ply. I probably said a few words you guys have never heard before.
In times such as these, I have been known to make up some new words.
Hope your damage gets under control real soon!
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it." - Mark Twain
"The intuitive mind is a sacred gift and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." - Albert Einstein
4 Hats Studio
swissarmygirl
Images: 129
Postby Mauleskinner » Tue Sep 02, 2008 9:15 pm
Sounds like a good fix, though...I'll have to file that away for when I learn new words. :lol:
David
Mauleskinner
Postby AmyH » Wed Sep 03, 2008 11:18 am
John, I am having the same exact problem with my roof in two different areas. I plan to do pretty much the same thing that you did. I am going to mix a little cabosil in with the epoxy to make it a bit thicker, then I am going to squeeze it in as best I can and put some heavy weights on top of it. I have a seam on the top that I should have tapped with fiberglass, and I think that is the culprit. I'll have to sand the area down and re-epoxy with some fiberglass tape across the seam. Then there will be a bit of repainting, and hopefully it will all hold together.
Let me know how your fix works out.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby tonyj » Wed Sep 03, 2008 11:21 am
John--I am always up for learning new words--I overuse the ones I know.
Amy--You might want to skip the Cabosil and just use epoxy. The added filler might work as a dam to prevent the epoxy from squeezing into the fringe areas, and it might even cause a lump. Just a thought.
tony
tonyj
Images: 160
Postby Mary K » Wed Sep 03, 2008 11:33 am
Sorry to hear about more problems John. :( Good Idea on the fix. Let us know how it turns out.
I got stung by a wasp the other day and in an instant it gave me a bad case of potty mouth. It was like being possessed. :oops:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby AmyH » Wed Sep 03, 2008 2:24 pm
Good thought Tony, that hadn't crossed my mind. I was thinking that straight epoxy might be too thin and would just soak into the wood. My thought was to make it a bit more "glue-like" by adding a bit of cabosil, just enough to make it a bit thicker.
Amy
Photo Log
AmyH
*The 300 Club
Postby Micro469 » Wed Sep 03, 2008 9:39 pm
It worked great! The ply is now perfectly flat, and the epoxy has completly sealed the area. Got dark too fast, came home late , so no pic. I'll post one tomorrow. You can see the cut marks, but that is to be expected.
John
Micro469
Images: 382
Postby AmyH » Thu Sep 04, 2008 10:19 am
Awesome John! I am soooooo glad to hear that it worked out great! Now I have to find time to do the same fix on mine.
Amy
Photo Log
AmyH
*The 300 Club
