Ok, Newbie Tear builder still confused on epoxy or resin
Postby Von Pook » Sun Nov 16, 2008 9:36 pm
I am building a woody style tear and continue to wonder about the exterior. My confusion is, what to cover it with. I would prefere something that is transparent and allows the beautty of the wood show through. Either fiberglass resin or epoxy resin. Is there a difference or am I losing my mind? :?
Eric, the camping sound guy
Von Pook
Images: 10
Re: Ok, Newbie Tear builder still confused on epoxy or resin
Postby Juneaudave » Sun Nov 16, 2008 11:11 pm
Von Pook wrote:I am building a woody style tear and continue to wonder about the exterior. My confusion is, what to cover it with. I would prefere something that is transparent and allows the beautty of the wood show through. Either fiberglass resin or epoxy resin. Is there a difference or am I losing my mind? :?
Holy Smoly Mr. Von Pook...you are indeed losing your mind!!! :lol: :lol: Bottom line is that an epoxy resin such as West, Raka or MAS can be used with or without a fiberglass cloth layer. Coating something with epoxy, in and of itself, doesn't add strength...but it does seal out the weather and build a nice surface for a varnish or poly finish coat. If you lay out a layer of fbergalss cloth...this thread might help...http://www.tnttt.com/viewtopic.php?t=24413&highlight=hatch
Juneaudave
Images: 380
Postby Von Pook » Sun Nov 16, 2008 11:54 pm
So Dave, if I ran down to the auto parts store, and got a gallon of fiberglass resin, would that be ok?
Von Pook
Images: 10
Postby del » Mon Nov 17, 2008 12:16 am
Von Pook wrote:So Dave, if I ran down to the auto parts store, and got a gallon of fiberglass resin, would that be ok?
No, chances are what you would come home with is polyester resin (brittle), and not epoxy resin.
del
del
5000 Club
5000 Club
Images: 410
Postby Juneaudave » Mon Nov 17, 2008 12:19 am
Well maybe, but you would most likely be buying polyester resin that may or may not give you the results that you are looking for. Take a look at the Raka, West, or MAS sites. These are really good and what you want!!!! Raka is probably cheaper...MAS and West are more widely distributed and can be found at marine suppliers and finer hardware stores.
Juneaudave
Images: 380
Postby asianflava » Mon Nov 17, 2008 3:03 am
Resin and epoxy are used interchangably which adds to the confusion. Epoxy is a resin but resin isn't necessarily an epoxy. There are resins like polyester which is to find. It works fine but it is not as strong, and can be tricky to work with because it is dependent on how it is mixed. On the upside, it is cheaper and doesn't need UV protection. An easy way to distinguish wether it is polyester or epoxy resin is by the price, epoxy is usually more expensive.
asianflava
Postby leaded » Mon Nov 17, 2008 7:06 am
After what i´ve read of posts, the polyester resin is more brittle. Would this make any trouble with cracks in the "shaking" of the caravan at travel, or is the epoxy resin best because it gives more strength, without making brittles?
:thinking:
"if your car need more than 2 hubcaps, it ain´t cool!"
leaded
Images: 23
Postby jimqpublic » Mon Nov 17, 2008 10:54 am
A wooden boat magazine I used to read when building my Kayak had a great article on using a light layer of glass cloth with epoxy to stabilize the surface of plywood used in a varnished topsides application. They said that otherwise the surface was much more likely to "check" due to the thermal effects of sun exposure. The thin layer of glass is basically invisible after varnishing.
So if I were to do a varnished or painted exterior it would have epoxy and glass to stabilize it, then varnish or paint for UV stabilization.
Jim
2002 Chalet Arrowhead but always wanted a Teardrop
2 kids and a Dear Wife
http://community.webshots.com/user/jimqpublic
jimqpublic
Postby doug hodder » Mon Nov 17, 2008 11:20 am
I've built all of mine using just epoxy over the plywood on the exterior, 2 woodies and 2 painted ones, no cloth. On the woodies I used an automotive clear, on the painted ones, base paint and clear. I also built 2 boats, used cloth on the hull, but not up on the top deck however varnish won't weather like an auto clear will. I've had no problems with any of them checking, but I don't leave them out in the elements year round. My opinion...the epoxy is a lot less of a nuisance to work with over the polyester. I also use it for my main construction adhesive. Doug
Not much UV protection with epoxy
Postby ZendoDeb » Mon Nov 17, 2008 11:52 pm
The high-gloss epoxies (even West System) don't contain much in the way of UV protection. In the South, it is recommended to cover with a couple of coats of varnish.
When it degrades, you can have a real mess on your hands.
3. Epoxies yellow, chalk (or more commonly least lose their gloss), in direct sunlight (UV). The yellowing can be a real problem. For pigmented epoxies select colors that are dark or contain a lot of yellow (such as green). Even clear epoxies will yellow and cloud up. Often epoxies are topcoated with latex or urethanes that will retain their color and attractive gloss. This is particularly true if color coding or matching company colors is important.
reference
"Houses are but badly built boats so firmly aground that you cannot think of moving them.... The desire to build a house is the tired wish of a man content thenceforward with a single anchorage. The desire to build a boat is the desire of youth, unwilling yet to accept the idea of a final anchorage." - Arthur Ransome: Racundra's First Cruise, 1923
ZendoDeb
Postby Tx River Rat » Tue Nov 18, 2008 12:10 am
Don,t mean to start a war here.
But I have built several kayaks that are used pretty roughly , bouncing of rocks drug up on gravel and sand beaches, and I used polyester with good results, and after several hundred miles on the river they are in good shape.
Epoxy does add strength if you coat both sides , then you have a composite which is 4 times stronger than a raw piece of wood.
Ron
Tx River Rat
2nd Teardrop Club
Postby Von Pook » Tue Nov 18, 2008 3:35 pm
I'd like to thank everyone for the responses to my query. Though now maybe I should start a poll and find out which is to be the winning finish on my tear :D lol. Thank you all again for your help and patience
Von Pook
Images: 10
Postby Esteban » Tue Nov 18, 2008 7:07 pm
I'm fiberglassing my teardrop with epoxy and fiberglass cloth from Raka.com. I'm using fiberglass cloth on the sides and on the top and galley lid.
On the sides I used a light weight tight weave fiberglass cloth. The tight weave made bubbles a little difficult to brush (tip) out. I think the fiberglass cloth helped to level out the epoxy. If I had a do over I'd use a plain weave 4 or 6 oz. cloth.
I have not begun fiberglassing the roof. On it I'll use 4 oz. (6 0z. would be OK too) plain weave cloth that has more of a gap between the criss crosssed strands. It should be easier to brush out bubbles.
On the sleeping cabin floor I'm using epoxy, without cloth, to seal the plywood. The successive coats of epoxy tend to orange peel and require more sanding to level than the sides (with fiberglass cloth) did.
A gotcha I've encountered is that on some real small batches the mix was wrong. They gelled up but never hardened. A PITB to scrape and sand off several days later. There may have been too much hardener in those bad small batches. The Raka hardener bottles said using too much can cause that.
Just some experience from a newbie. Overall I'm pleased with epoxy and fiberglass.
Also the 1/4" sanded plywood, with a grade A face, for the sides was from a local lumber yard. It was very smooth with almost no voids visible between ply layers. For the cabin floor I used 3/8" Orange Box sanded plywood. The local lumber yard plywood cost a little bit more but it seemed easier to epoxy/fiberglass to get a smooth even surface, with less sanding and wasted epoxy, than Orange Box plywood.
edited to add: I'm using a foam roller (from Raka) to spread out the epoxy. I only use a foam brush to very lightly tip off (break) the bubbles that form. Also use a plastic paint edger from HD to help spread epoxy around and to fill in low spots, like nail holes or plywood joints, with epoxy that has begun to thicken.
Steve - SLO, CA
Esteban
Images: 15
Postby doug hodder » Tue Nov 18, 2008 7:18 pm
Steve...just an idea, don't use a brush to wet out glass cloth, use a squeege. A body putty squeege works well. Mashes the resin into the cloth and smooths it down. Doug
Postby starleen2 » Tue Nov 18, 2008 7:27 pm
doug hodder wrote:Steve...just an idea, don't use a brush to wet out glass cloth, use a squeege. A body putty squeege works well. Mashes the resin into the cloth and smooths it down. Doug
Would have to agree with doug - I learned the hard way with a brush. Sure it works ok, but the many hours of sanding to remove brush marks was tedious and dusty.
starleen2
5th Teardrop Club
