Von Pook wrote:I am building a woody style tear and continue to wonder about the exterior. My confusion is, what to cover it with. I would prefere something that is transparent and allows the beautty of the wood show through. Either fiberglass resin or epoxy resin. Is there a difference or am I losing my mind?
No, chances are what you would come home with is polyester resin (brittle), and not epoxy resin.Von Pook wrote:So Dave, if I ran down to the auto parts store, and got a gallon of fiberglass resin, would that be ok?
reference3. Epoxies yellow, chalk (or more commonly least lose their gloss), in direct sunlight (UV). The yellowing can be a real problem. For pigmented epoxies select colors that are dark or contain a lot of yellow (such as green). Even clear epoxies will yellow and cloud up. Often epoxies are topcoated with latex or urethanes that will retain their color and attractive gloss. This is particularly true if color coding or matching company colors is important.
doug hodder wrote:Steve...just an idea, don't use a brush to wet out glass cloth, use a squeege. A body putty squeege works well. Mashes the resin into the cloth and smooths it down. Doug
