Ivar the Red wrote:Ok. But wouldn't the solid sides last longer?
grant whipp wrote:Who says you've got to add framing to include insulation? Why not cut your profile from 1/2" or 3/4" plywood, cut a bunch of lightening holes where you don't need strength for windows, doors, or cabinetry ... panel the inside with 1/8" plywood paneling ... stuff 1/2" or 3/4" foamboard insulation in the holes ... then cover with 1/8" or 1/4" plywood (I prefer 1/4" if I'm gluing the aluminum to the sides) ......
tinksdad wrote:grant whipp wrote:... Why not cut your profile from 1/2" or 3/4" plywood, cut a bunch of lightening holes where you don't need strength for windows, doors, or cabinetry ... panel the inside with 1/8" plywood paneling ... stuff 1/2" or 3/4" foamboard insulation in the holes ... then cover with 1/8" or 1/4" plywood ...
... I hadn't considered using 1/2" for the framing sheet; but I will now. I do have a question though... What kind of ply to use for the framing part? I would think that regular sheathing would not be the right choice. I'd be afraid that it would warp too much. I would imagine something with more plys for stability?
