What did you use to waterproof and paint your camper
Postby zlamb0002 » Thu Nov 20, 2008 12:53 pm
Well what did you use?
How long has it lasted?
Did it do a good job?
zlamb0002
Postby Miriam C. » Thu Nov 20, 2008 3:38 pm
I used Helmsman spar varnish at firs. Don't think I got enough layers on because the ply cracked and grayed under it.
Second time I put marine epoxy then Minwax Clear Sheild. It seems to be better and is certainly more the ambered look I was after.
Postby wingnutt111 » Thu Nov 20, 2008 8:27 pm
i was thinking using mvp (stuff to glue floors down with) has anyone done this or know anything about it?
someone said no to me today!,what does this mean?
wingnutt111
Images: 19
Postby tinksdad » Thu Nov 20, 2008 8:45 pm
3 coats of 3 to 1 mixture mineral spirits and spar urethane...
2 coats of Kilz....
3 coats of Rustoleum enamel (aluminum finish)
So far no problems! Just finished the tear about 6 weeks ago. The acid test will be after it sits outside all winter uncovered!
tinksdad
Images: 155
Postby planovet » Thu Nov 20, 2008 10:15 pm
2 coats CEPS
3 coats primer
5 coats Valspar Supreme Acrylic Enamel
I haven't finished my tear yet so I don't know about lasting properties. It looks good though!
ImageMark (& Cindi)
planovet
The Cat Man
Postby looped » Thu Nov 20, 2008 11:40 pm
spar urathane 2 coats
zinzer oil based primer 3 coats
rust oleum brush on oil based 3 coats
holding up well although i will be repainting it in the spring. not because of any material failure, just because i was kinda rushed when painting it and it shows to my eyes.
with any project, take your time and you wont have to do it again.
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby GPW » Fri Nov 21, 2008 7:11 am
I'm with Tinksdad... that min/urethane mixture really sinks in and encapsulates the wood fibers, making them impervious to water intrusion...then a good primer....then paint... Doing a good paint job involves a Lot of surface prep and sanding/cleaning between layers... Done right it will last many years ....done hastily without proper prep, you'll be touching it up next season... :o
Postby kirkman » Sat Nov 22, 2008 4:15 pm
Duraback truck bed liner. Very happy with it. But if I had to do it over I would just go to the rhino-lining dealer and have him apply it. It would have been the same price with out the hassle.
kirkman
Images: 55
Postby tinksdad » Sat Nov 22, 2008 6:19 pm
GPW wrote:I'm with Tinksdad... that min/urethane mixture really sinks in and encapsulates the wood fibers, making them impervious to water intrusion...then a good primer....then paint... Doing a good paint job involves a Lot of surface prep and sanding/cleaning between layers... Done right it will last many years ....done hastily without proper prep, you'll be touching it up next season... :o
I'm repainting in the spring!! Not because of anything to do with water-proofing. I'm just not happy with the color. I wanted some red on the tear when I started and don't now why I changed in mid-stream. It will be red in the spring!!
tinksdad
Images: 155
Postby stbuch » Sun Nov 23, 2008 7:54 am
Silicone caulk on all seams and screw heads, Exteriror semi-gloss 3 coats, Spar urethane 2 coats.
Good grief, isn�t it the weekend yet?
Maybe if I sleep in the camper the week
will pass faster�
stbuch
Images: 92
