Well what did you use?
How long has it lasted?
Did it do a good job?
GPW wrote:I'm with Tinksdad... that min/urethane mixture really sinks in and encapsulates the wood fibers, making them impervious to water intrusion...then a good primer....then paint... Doing a good paint job involves a Lot of surface prep and sanding/cleaning between layers... Done right it will last many years ....done hastily without proper prep, you'll be touching it up next season...
