Oil or Water based primer and paint over Spar Urethane
Postby zlamb0002 » Mon Dec 01, 2008 10:50 pm
It is probably a stupid question. Which one oil or water primer and in your opinion what is the best brand.
zlamb0002
Postby Micro469 » Mon Dec 01, 2008 11:58 pm
Basically, when anything has to be painted, or repainted, I use oil based primer. Reason... Don't always know what the base coat is, and also it seems to "stick" better.... Better safe than sorry... :thumbsup:
John
Micro469
Images: 382
Postby rainjer » Tue Dec 02, 2008 12:23 am
Micro469 wrote:Basically, when anything has to be painted, or repainted, I use oil based primer. Reason... Don't always know what the base coat is, and also it seems to "stick" better.... Better safe than sorry... :thumbsup:
That is not correct. You should not use oil base paint over water based paints. They will not adhere correctly. The oil need something to penetrate in order adhere properly. You can paint water based paint over both oil based & water based paints as long as the base paint is dry.
Jeremy
rainjer
King Koleman
Images: 11
Postby jawbone » Tue Dec 02, 2008 9:14 am
I used oil based "Zinsser" high adhesive primer, then oil based "Rust Coat". The latex primer seemed to want to "bead" a bit. Everything was sanded. It needs more coats but it was time to go campin'!!!
Blues, The Whole Blues and Nuthin' But the Blues
jawbone
