Propane
Propane
Postby john curtis » Mon May 04, 2009 11:05 pm
Hi Everybody.Finally getting back to work on the TD after a long and cold winter.Am thinking about putting my 10 LB. propane bottle under the counter in the galley to concerve space in the tounge box and to also shorten up the hose to the stove.My question is do I need to have a vent to the outside , or should it be mounted out at the tounge beside the box.
john curtis
Images: 141
Postby kennyrayandersen » Mon May 04, 2009 11:56 pm
that's where I was thinking of putting mine. Since you only ever use it to cook with the hatch open, and there is no path for the gas to get to the cabin part of the tear, I'm not sure what the trouble with it might be. I was thinking 10 lb tank as well since I probably won't be going for more than a few days at a time.
kennyrayandersen
Images: 38
Postby oldtinker » Tue May 05, 2009 12:09 am
Make sure you vent it at the bottom. Propane is heavier than air.
If your tank, valve or connection was seeping you could build up a pool of gas that would be a bomb waiting for any spark.
If you parked for a while and the leak had started from vibration while driving you could open the hatch, light something and BOOM!
Not something you want to do,
Presley
"Nothing in the world can take the place of perseverence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent.
<b>-- Calvin Coolidge</b>
oldtinker
Images: 6
Postby kennyrayandersen » Tue May 05, 2009 1:46 am
oldtinker wrote:Make sure you vent it at the bottom. Propane is heavier than air.
Presley
duly noted :thumbsup:
kennyrayandersen
Images: 38
Postby Dale M. » Tue May 05, 2009 10:23 am
Presley
Ditto!
Dale
Dale M.
Images: 18
Propane
Postby john curtis » Tue May 05, 2009 9:13 pm
Thanks for the input.Now what would be better venting out the wall at the bottom of the tank or venting out the floor?
john curtis
Images: 141
Re: Propane
Postby Dale M. » Tue May 05, 2009 9:28 pm
john curtis wrote:Thanks for the input.Now what would be better venting out the wall at the bottom of the tank or venting out the floor?
Think of propane as water.... Where would the water flow to.... Put vent (drain) there.....
Dale
Dale M.
Images: 18
