Table edge t molding & Cove molding
Postby kurtibm » Tue Sep 29, 2009 5:35 pm
I'm hunting for some 3/4" aluminum vintage look table edge t-molding for use on the edge of my counter and flip-down table. (I'd prefer the ribbed variety, like you'd see on a table in a diner) I could also use the plain edge molding that gets nailed into the edge as a second-best option.
And also some aluminum cove molding for use on the joint between the countertop and the walls. I'd like it to run up about 1/2" on the wall+/-.
Has anyone found a good affordable source for these?
Thanks in advance,
Kurt
It is not the years in your life that matter, it's the life in your years.
kurtibm
Images: 29
Postby prohandyman » Tue Sep 29, 2009 6:21 pm
Dan
prohandyman
Images: 785
Postby doug hodder » Tue Sep 29, 2009 7:01 pm
Here's what I've found on the cove molding, reasonably priced...you be the judge. I haven't found it anywhere else, unless you are buying bulk on it. Mine is on the way, I got the 1/2". It's the look I want. Teardrop-fix-it, used to carry it, but not anymore. Doug
http://www.vintagetrailersupply.com/Mou ... m_s/64.htm
Postby kurtibm » Tue Sep 29, 2009 7:34 pm
Thanks Dan & Doug .... I appreciate the leads .
Doug >> http://www.outwatercatalogs.com/lg_display.cfm/page/378/catalog/2009_master
kurtibm
Images: 29
Postby doug hodder » Tue Sep 29, 2009 7:49 pm
That one never came up in my searches. Oh well. Doug
Postby bve » Tue Sep 29, 2009 9:28 pm
Have you tried Home Depot? I'm sure I've seen it there - at least up here north of the 49th.
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
