roof edge molding - sealant question
Postby Dick » Thu Oct 08, 2009 7:13 pm
Getting ready to add the roof edge molding in next couple of days. Is there a recommended method such as using butyl tape under the trim or using a silicone - or something else?
Thanks in advance for the advice
Dick
Images: 11
Postby wannabefree » Thu Oct 08, 2009 8:21 pm
A lot of people use silicone. I hate the stuff and use something called Lexel. It's water clear, cleans up with paint thinner, and is paintable. Silicone isn't clear, is a bear to clean up, and won't take paint.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby madjack » Thu Oct 08, 2009 9:29 pm
I used hi-tek stuff on the first one...on the second, I used standard RV butyl tape...pulled it over the edges and then applied the trim...inexpensive, will stay pliable/hold a seal for a long time and is removable if needed.........
Postby Steve_Cox » Fri Oct 09, 2009 7:23 am
butyl tape :thumbsup:
silicone sealant - just a nasty mess destined to fail :lol:
If you have any plywood end grain exposed, it is a good idea seal it with several coats of epoxy.
Steve_Cox
Images: 196
Re: roof edge molding - sealant question
Postby Classic Finn » Fri Oct 09, 2009 1:39 pm
Dick wrote:Getting ready to add the roof edge molding in next couple of days. Is there a recommended method such as using butyl tape under the trim or using a silicone - or something else?
Hello Kansas City and Greetings from the Country of Finland.
Butyl Tape is also used on our tear. However with a small exception or slight mod. Here I used RV Molding with a 2 in 1 Rubber Seal with Butyl Tape on the bottom side. No leaks at all. Notice the thin layer of plastic. That is peeled off as you set the seal/butyl tape down under the moulding.
Our style of RV Moulding below.
And Rubber Seal/ Butyl Tape in 1 conformed to the above moulding.
Best regards
Classic Finn and Family :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby planovet » Fri Oct 09, 2009 2:30 pm
madjack wrote:I used standard RV butyl tape...pulled it over the edges and then applied the trim...inexpensive, will stay pliable/hold a seal for a long time and is removable if needed......
+1 That's what I did :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
thanks for all your advice
Postby Dick » Sat Oct 10, 2009 7:26 am
Appreciate all the advice - decided to use the butyl tape for sealing - easier than the messy silicone stuff. Used the butyl tape for the hurricane hatch hinge and the result was a "good looking" install and no mess. On the contrary I used silicone to seal around the vent fan as per mfg instructions and my caulking skills looks like #$@%. Oh well, it's on the roof where most people can't see it up close and as long as it doesn't leak it will be fine.
Again thanks to all!![/code]
Dick
Images: 11
