cappy208 wrote:But I still cant get over the intentional drilling of MORE holes in the roof to have to seal.... in addition to the original holes from the roof panel!
John
Gage wrote:cappy208 wrote:But I still cant get over the intentional drilling of MORE holes in the roof to have to seal.... in addition to the original holes from the roof panel!
John
What are you talking about? Sounds to me that your trying to make a mountain out of a mole hill. If your doing a restore and you use the correct edge molding, the holes should just about match up. Have you got any pictures?
Carter wrote:Put it on with all the fasteners then take it off again, add a bead of good quality butyl caulk when reinstalling
John
I used alum twist nails. I pre formed my molding because I was using nails. I then applied sealant and did as Mark did. Clamp and pre drilled and installed nails (or screws) one at a time.Classic Finn wrote: Gage are them screws or nails you used on the edge trim? If I remember correctly you mentioned someplace that you have or will use rounded top nails or am I wrong.Your work is so Finntastic as always.
Classic Finn
John
steve smoot wrote:Boy, Gage has more clamps than that fellow, Norm...
Users browsing this forum: Jimbodub and 2 guests
