by eamarquardt » Tue Nov 24, 2009 11:29 am
On my dump trailer (see album) I used watertight flex conduit. The wiring will outlast me by several genarations.
On my tear, I used 2X3 tubing and plan to run the wires inside the tubing. I'll used electrical fittings to protect the wires as they enter and exit the tubing. You can drill a 1 inch or so hole in the sidewall without significantly affecting the strenght of the tubing but I wouldn't drill into the top or bottom as that would weaken it (but probably not enough to matter.
Hope this helps.
Gus
