It's a pain.. ok mainly in sand, to luge my tear around by hand. Has anyone setup a powered front caster so you can walk your baby into position with just a finger? Maybe take it for a walk around the park even?
Design I'm looking for would use the 12V battery for power and a pneumatic wheel.
there are a lot of similar tugs used to put light aircraft in and ot of the hangar. o lurk at an a local airport and check out what there is there.
We airplane folk usually are a friendly bunch!
A friend of mine hooked up a motorized front wheelchiar wheel to help someone push around their boat. The 6" wheel has a 12v gear motor mounted near the axle. You could do the same. But you have to call it the "BertWheel" because that's what he named it.
