Powered Front Wheel Design
Postby campadk » Sat May 14, 2005 5:49 pm
It's a pain.. ok mainly in sand, to luge my tear around by hand. Has anyone setup a powered front caster so you can walk your baby into position with just a finger? Maybe take it for a walk around the park even?
Design I'm looking for would use the 12V battery for power and a pneumatic wheel.
Single speed is fine. :thumbsup:
campadk
Teardrop fun specialist
Images: 34
Postby Geron » Sat May 14, 2005 6:31 pm
I'm thinking maybe a 5 speed with a "Hemi" - forget the TV. :roll:
Geron
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby ceebe » Sat May 14, 2005 7:27 pm
there are a lot of similar tugs used to put light aircraft in and ot of the hangar. o lurk at an a local airport and check out what there is there.
We airplane folk usually are a friendly bunch!
ceebe
Postby Dave Nathanson » Mon May 16, 2005 2:32 pm
A friend of mine hooked up a motorized front wheelchiar wheel to help someone push around their boat. The 6" wheel has a 12v gear motor mounted near the axle. You could do the same. But you have to call it the "BertWheel" because that's what he named it.
Dave Nathanson
Images: 19
Postby madjack » Mon May 16, 2005 11:08 pm
Postby asianflava » Mon May 16, 2005 11:30 pm
Not powered, but I couldn't resist the price of $19. It would cost more to buy the tires if you made one yourself.
asianflava
