by wannabefree » Sat Jan 09, 2010 11:45 pm
I too would recommend aniline dye. It is soluble in alcohol or water, depending on what you get. I use Transtint dyes, available from Woodcraft. You can mix and match to get the color you want. I am skeptical about adhesion of epoxy, or anything else for that matter, to oil based stains. You can even add Transtint to the epoxy, though I have never tried it and would recommend some serious testing before committing to anything like that. I'm not totally down on oil based stain and use it in cabinetry, but a Tear sees weather, cabinets don't.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
