Epoxy and stain
Epoxy and stain
Postby alftinc » Sat Jan 09, 2010 7:11 pm
I see that CPES recommends using an oil based stain if staining the wood. Has anyone used stain under regular epoxy resin and if so was it water or oil based, and did it work well. I would like to coat my Generic Benroy with an oil based stain and then use regular Epoxy resin to seal it from the weather topped of course with a good uv varnish.
alftinc
Images: 7
Postby Juneaudave » Sat Jan 09, 2010 7:48 pm
Be sure to check out this article Epoxy Adhesion over Stains. You want to assure compatability...Dave
Juneaudave
Images: 380
Postby doug hodder » Sat Jan 09, 2010 9:27 pm
I've had real good results with epoxy over aniline dye. The advantage is that you can blend the dye easily and if it's on too heavy, take some off with a damp sponge or rag. Dyes can be purchased from Woodworkers Supply, Rocklers etc....Doug
Postby wannabefree » Sat Jan 09, 2010 11:45 pm
I too would recommend aniline dye. It is soluble in alcohol or water, depending on what you get. I use Transtint dyes, available from Woodcraft. You can mix and match to get the color you want. I am skeptical about adhesion of epoxy, or anything else for that matter, to oil based stains. You can even add Transtint to the epoxy, though I have never tried it and would recommend some serious testing before committing to anything like that. I'm not totally down on oil based stain and use it in cabinetry, but a Tear sees weather, cabinets don't.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Ageless » Sun Jan 10, 2010 12:33 am
Regardless of water or oil bases; the important point is to allow the wood with stain applied to dry. Epoxy laid over any damp wood, either water or ail based is not going to adhere to the wood itself
Ageless
Postby reiltear » Mon Jan 11, 2010 1:10 am
I did not use CPES or West System epoxy, but I had the same results as in the article Dave linked to.
reiltear
Images: 18
