floor thickness 1/2 or 3/4
Postby rwelp » Sun Jan 31, 2010 9:12 am
What's the general consensus here about how thick the plywood floor should be. I finally finished my wife's Morris chair and ottoman and am going to start my build. I am going to pick up my trailer today from my brother in laws house and then go to H.D to get ply for the floor and get started.
Rob : :roll: ;)
Rob Welp
Build Pics
rwelp
Images: 66
Postby toypusher » Sun Jan 31, 2010 9:26 am
I used 1/2" on an HF trailer. Just think about how you will be using the space on top of the plywood. When inside the tear your weight will be distributed quite a bit and in my opinion 1/2" is plenty. My floor does not flex at all.
toypusher
Images: 324
Postby doctor phreak » Sun Jan 31, 2010 9:42 am
i used 3/4" to do my floor just because i went with no insulation...plus i also wanted the sturdiness of it.....
doctor phreak
Postby afreegreek » Sun Jan 31, 2010 9:57 am
you'd do well to consider how many cross members there are on your frame, how far they are apart, what else there is, if anything between the frame and the ply, how you are going to attach the walls and to what, and how far the floor will overhang the frame if at all. lets say you're going to use carriage bolts to bolt the 1/2" ply to the frame. once you counter bore for the heads that leaves 1/4" of meat holding the two together. with 3/4" you have 1/2" left. IMO all you save using 1/2" ply is 20 lbs and $20..
afreegreek
Postby rwelp » Sun Jan 31, 2010 11:30 am
The trailer frame is 5x9 and ther are 4 inner cross braces made of steel. There will be 1x or possibly 2x wooden framing under the plywood floor. There will be no overhang past the steel frame, but there will be a drop down in the floor. I am thinking 1/2 will be enough except for possibly the drop down floor. Iv'e been looking forward to my build for a long time. Can't wait to actually start.
Rob
Rob Welp
Build Pics
rwelp
Images: 66
Postby synaps3 » Sun Jan 31, 2010 1:52 pm
Mine is 3/4" with 1x3" subframe. It's got 18" of overlap, and is rock solid.
If I had no overhang, and wasn't towing a motorcycle, I would have gone with 3/8" ply with no subframe. Anything past that is overbuilding.
-- Dave
Build log: here
synaps3
Images: 254
How about?
Postby eamarquardt » Sun Jan 31, 2010 2:44 pm
I plan on using 1/2 on top 1" insulation with a few wood stringers, and 1/4 on the bottom. Almost the same weight of 3/4 but insulated and much stronger!
Hope this helps.
Gus
eamarquardt
Images: 150
Postby GreatPumpkin » Sun Jan 31, 2010 3:45 pm
Sandwich floor, bottom to top:
1/16" Plam
1/2" Baltic Birch
3/4" (1x3 white wood framing with insulation in between)
3/4" solid hardwood flooring, glued and nailed.
Custom Benroy/Grunman/Hybrid...In Progress
2001 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus." GP
GreatPumpkin
Images: 5
Postby wannabefree » Sun Jan 31, 2010 7:42 pm
My floor, which I now consider overbuilt, is (top to bottom):
3/8 baltic birch
1x4 frame with cross brace every 1-1/2 feet
1/4 baltic birch
with a couple 3/8 steel tension rods to make sure nothing rattles apart over the wheel wells.
The 1x4 frame was needed to build out over the wheels, but on the ply I would reduce to 1/4 and 1/8 respectively.
Weight matters
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Kens » Sun Jan 31, 2010 7:59 pm
1/2 ply and 1x4s for the frame. I am not standing on it.
Good day every day!
Kens
Images: 26
Postby AZSpyder » Sun Jan 31, 2010 8:06 pm
My Puck uses 7/16 hardwood ply and there's probably not more then 2 1/2 foot between cross members. I replaced it with the same and it seems plenty solid.
Jerry
AZSpyder
Postby Gage » Sun Jan 31, 2010 8:08 pm
3/4 ply and no sub frame (not needed when using 3/4 for a teardrop build). Keep it simple and don't over engineer.
There is nothing hidden in the above post.
Image Image Image
Gage
Images: 28
Postby Sam I am » Sun Jan 31, 2010 8:37 pm
I had planned to use 3/4" ply on my floor, but the plywood supplier had some 5/8" fir plywood in a 5'x8' size. My trailer frame is also 5'x8', so I used the 5/8" wood for a one-piece floor. It seems plenty strong!
Sam I am
Images: 106
Postby aggie79 » Mon Feb 01, 2010 9:28 am
With all of the crossmembers you have on your trailer, 1/2" will be fine. Something to consider, though, is how your walls will fasten to the floor. 1/2" material doesn't give much thickness for fasteners.
Postby NathanL » Mon Feb 01, 2010 10:04 am
aggie79 wrote:With all of the crossmembers you have on your trailer, 1/2" will be fine. Something to consider, though, is how your walls will fasten to the floor. 1/2" material doesn't give much thickness for fasteners.
Is anyone really attaching a wall to the floor directly by screwing into the end grain of plywood?
NathanL
