What chemical/epoxy? to put on road side of floor...
Postby DasBaldGuy » Fri Feb 05, 2010 7:56 am
Sorry, I know this must be the millionth time someone has asked this, but what should I use to coat the underside of the floor (road facing) to seal the plywood?
I know I need
1) Some kind of epoxy/polyeurathane
and
2) Some kind of black/tar-like undercoating
Can someone recommend stuff to use that is readily available at Home Depot and/or Lowes?
I am at the floor portion of my build (photos of newly powdercoated frame will be posted to my buildthread)
thanks guys!
DasBaldGuy
Postby absolutsnwbrdr » Fri Feb 05, 2010 8:23 am
well, I can't speak for the polyurethane, but I plan on using this black goo.
Every seems to speak highly of it.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby synaps3 » Fri Feb 05, 2010 10:46 am
No epoxy is needed -- that's overkill. Even using an asphalt-based roof sealant (what most people use) is overkill.
I have a 30-year-old utility trailer that I bought from someone who had always stored it outside. The undercarriage has no coating, and the ply is holding up fine.
I don't want to risk it on my TTT, so I'm using Henry Asphalt Emulsion coating. They have it at Home Depot in the roofing section, about $15 a gallon. Read the cans until you find one that'll work. :thumbsup:
-- Dave
Build log: here
synaps3
Images: 254
Postby afreegreek » Fri Feb 05, 2010 11:23 am
the two things that will damage wood are high moisture content and the sun. since the bottom of the trailer is shielded from the sun it's not a problem and because it's open to the air it will dry out after getting soaked. only the parts that are in contact with the trailer frame will stay wet. so that is your only real problem area.
afreegreek
Re: What chemical/epoxy? to put on road side of floor...
Postby planovet » Fri Feb 05, 2010 11:30 am
DasBaldGuy wrote:Sorry, I know this must be the millionth time someone has asked this, but what should I use to coat the underside of the floor (road facing) to seal the plywood?
I know I need
and
thanks guys!
Not the millionth time but definitely in triple digits :lol:
If you are using the "black goo" (as I did), you don't need to epoxy beforehand. Some say it's overkill but many on this forum have used it and have had no problems. It's also cheap and easy and available at the big box stores. Just be sure to wear gloves and old clothes.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Ageless » Fri Feb 05, 2010 12:09 pm
30 years ago we weren't getting plywood from who knows where. With so much questionable content and questionable manufacturing; do you want to take that risk? I'd rather seal it up than have to tear it apart in a few years. That luan labelled 'water resistant' is a prime example.
Ageless
Postby S. Heisley » Fri Feb 05, 2010 12:26 pm
You can use both, if you want to. It may well be overkill, but it's your build and you can do what makes you feel the most comfortable. If you use epoxy, put it on first and then lightly sand it with some 100 grit sandpaper, before you top it with the black roofing goo. I used CPES because I know it is good; but, it costs a little more and others might work okay as well. Note: CPES needs a follow-up with some sort of UV protection, either black goo or paint.
Postby afreegreek » Fri Feb 05, 2010 1:10 pm
Ageless wrote:30 years ago we weren't getting plywood from who knows where. With so much questionable content and questionable manufacturing; do you want to take that risk? I'd rather seal it up than have to tear it apart in a few years. That luan labelled 'water resistant' is a prime example.
the plywood products available now are generally superior to the stuff from 30 years ago assuming you're not getting it from Home Depot. going to a place like that and buying a sheet of cheap, low grade material suitable for a garden shed and expecting it to be anything other than garden shed material is wishful thinking at best.
afreegreek
Postby synaps3 » Fri Feb 05, 2010 1:18 pm
afreegreek wrote:the plywood products available now are generally superior to the stuff from 30 years ago assuming you're not getting it from Home Depot.
I'm in full agreement here. I hear all sorts of comments about the plywood back in the good old days, but I've had great experiences with all the plywood I get -- even the crap from Home Depot.
I will admit they do have options for lower-grade stuff, such as the luan with a fiber core, but if you know what you're looking for, you avoid it and get the nice stuff.
-- Dave
Build log: here
synaps3
Images: 254
Postby Senior Ninja » Fri Feb 05, 2010 8:28 pm
For me it was three coats of varnish applied by brush. Special attention was given to the edges. Turned it over and did the same thing on the top. So far-so good. But then I love the smell of varnish in the morning. I grew up in the family paint factory on Chicago's South Side.
Building the TD was the best thing I ever made.
Senior Ninja
Postby wannabefree » Fri Feb 05, 2010 11:41 pm
I put on a coat of epoxy and taped the seams. Then a coat of tar stuff in a spray can from the auto parts store. Actually 6 cans.
I agree the epoxy is not necessary, but it gave me some experience I wouldn't have had otherwise when I put epoxy on the walls and top. That alone was worth the extra cost and effort.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Gage » Sat Feb 06, 2010 12:20 am
This is what works for me. And in my travels, my teardrop has gotten real wet and still no problems. :thinking:
Image Image Image
Gage
Images: 28
Postby Nosty » Sun Feb 07, 2010 5:35 pm
I'm working on mine now and I put two coats of Kilz Premium, two coats of Valspar Porch and Deck paint and I bought a 5 gal. pail of Rubr-Coat #57 (rubber roof coating aka, black goo), at HD for $28 to add the icing on the cake, so to speak.
Hope that helps add to your confusion. :? I kinda refined all the information I've read on all the posts and congealed it into that cocktail.
"I'm not talking to myself; I'm conversing with one of the myriad of voices in my head!"
View my build blog: http://www.briangreenleaf.wordpress.com
Visit my website:
http://www.bgreenleaf.com
Nosty
Images: 41
Postby Gage » Sun Feb 07, 2010 5:59 pm
Nosty wrote:I'm working on mine now and I put two coats of Kilz Premium, two coats of Valspar Porch and Deck paint and I bought a 5 gal. pail of Rubr-Coat #57 (rubber roof coating aka, black goo), at HD for $28 to add the icing on the cake, so to speak.
Seems like a lot of over spending to me. Money that could be used else where. And every one complains about the cost to build a quality teardrop. But what do I know? :thinking:
Image Image Image
Gage
Images: 28
Postby mikeschn » Sun Feb 07, 2010 6:04 pm
Black goo...
It's cheap... and it's insurance!!!
