okorokor wrote:Thanks for the two posts! Sounds like I am in the ballpark. Note that two 4x4 joists will extend 8 ft on each side, and 2 x 4 joists (6 ft long) will extend between the two 4x4s. Unfortunately the floor joists are necessary to be able to remove the teardrop shell from the flatbed trailer. I am using the two 8 ft. 4x4s, because I don't think 2 x 4s will be strong enough for an 8 ft. span, when the teardrop shell is propped up on cement blocks, at each corner.
Rock wrote:My camper has no frame at all. The floor rests on only the spring brackets from the HF 1175# trailer.
Needless to say I can lift the whole camper right off the axle and it doesn't break in half. As shown this whole rig weighs 400 lb.
Eric
okorokor wrote:I am using the two 8 ft. 4x4s, because I don't think 2 x 4s will be strong enough for an 8 ft. span, when the teardrop shell is propped up on cement blocks, at each corner.
Users browsing this forum: Bing [Bot] and 7 guests
