jcwhitney herculiner
Postby Grid Runner Adventures » Fri Mar 05, 2010 9:41 am
was searching around for rhinoliner alternatives and found herculiner for only 30 bucks a gallon (1 gallon enough for 6ft truckbed)
reading the reviews it appears to have a fairly rough finish due to the rubber particles in it.
i wonder how adversely that rough finish would affect the camper going down the road. should i look for a coating with no rubber particles in it. does anyone know of one. originally i was going to use FRP on the outside of the camper which is pebbled as well so i guess you cant get totally smooth.
no wind tunnel tests here lol.
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby synaps3 » Fri Mar 05, 2010 9:49 am
The bumps or roughness won't affect aerodynamics too much. Golf balls are dimpled, which actually improves their aerodynamics.
Shape is more important than texture, if we're only talking aerodynamics. Herculiner shouldn't be an issue.
If you want a smooth finish with bed liner, look into Durabak. It's expensive though...
-- Dave
Build log: here
synaps3
Images: 254
Postby Grid Runner Adventures » Fri Mar 05, 2010 9:51 am
ty i wonder how much area is in a 6ft truck bed. so i can calculate how much ill need for my camper.
Postby Grid Runner Adventures » Fri Mar 05, 2010 9:54 am
ah jcwhitney's site bamboozled me heh said the price was 31 bucks for a gallon kit then you click add to cart and its 136 heh checking durobak now.. ah 139 and smooth finish.
what other liners out there are cheaper?
Postby Grid Runner Adventures » Fri Mar 05, 2010 11:19 am
does anyone know what kind of finish plasti-kote gives. i cant find any info on it but its cheep and locally available
Postby Endo » Fri Mar 05, 2010 5:35 pm
Grid Runner Adventures wrote:does anyone know what kind of finish plasti-kote gives. i cant find any info on it but its cheep and locally available
I picked up a gallon not long ago. It is a rough finish. It has rubber particles in it as well.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Grid Runner Adventures » Sun Mar 07, 2010 11:56 am
any idea how much area one of these gallons coats. they just state in truck bed size (as thats what its geared for)
Postby Lou Park » Sun Mar 07, 2010 9:14 pm
There is a guy on ebay selling herculiner at $65 a gallon + 20 for shipping. He is in Northbrook IL if you want to make the trip. I would count on 2 gallons for a tear.
Lou
Lou Park
Images: 5
Postby Grid Runner Adventures » Sun Mar 07, 2010 9:20 pm
got a link for it i'll give him a call see what colors he has.
Postby Me&T » Mon Aug 16, 2010 11:03 pm
not sure if Herculiner is UV resistant, but I know you can buy Durabak that is UV resistant (very important when you live in the desert and it averages 300+ days of sun a year). I'm planning on using smooth, UVR, Durabak
Me&T
Postby Off Grid Rving » Wed Aug 18, 2010 1:19 pm
Herculiner is one of my sponsors now, The entire outside and the floor and 5 inches up the walls inside are all Herculined on my Ogre Rv. It sure turned out nice! not a single leak. I even used Herculiner to seal around some fittings bolted to the roof.
Check out http://offgridrving.com
--Update--
http://offgridrving.com has been transformed into Community Sites - where you can sign up for your very own project site, chronicle your experiences on the journey at http://offgridrving.com
Get your own space to post updates and pictures and even videos of your build.
Off Grid Rving
Postby firemaniac » Wed Aug 18, 2010 4:34 pm
When I used Herculiner I emailed the company, I calculated the area I needed to cover, roughly 4 sheets of plywood or approximately 128 square feet, they said I would need 2 gallons, and I used every last bit of it.
Chris
When in doubt, run in circles, scream, and shout!
firemaniac
Postby Off Grid Rving » Wed Aug 18, 2010 5:00 pm
ya I did 4 gallons every last bit of it on my standup camper.
--Update--
Off Grid Rving
Postby Forrest747 » Wed Aug 18, 2010 6:26 pm
been thinking of using some sort of bedliner for the front lower half of my build, to protect from debris. also thought of block diamond plating to match my jeep.
Forrest747
Cowbell Donating Member
Images: 447
Postby firemaniac » Wed Aug 18, 2010 7:44 pm
The only thing I didn't like about the Herculiner, was the sand paper like texture. Every time I bumped into the outside wall, I got a bit of an abrasion. defiantly get some samples and compare textures.
Chris
firemaniac
