Looking for a Tool - Dont know the name in English
Postby Classic Finn » Sat Mar 20, 2010 11:36 am
Hey folks. I was trying to look for a tool that makes a cut into tubing the same radius as the tube itself.. Im building the roof rack for our tear and I have a tube and or pipe bending tool however in order to splice into the tube it gives a rounded or diameter equal cut like tube itself.
Im lost in my words for it in English..I went looking for this tool cutter however I cant find anything like it..any name or photo or link would be of help. ;)
I know that the tube can be welded to the other however it would be helpful and easier to do so if the tube is cut at the end to match the radius of that specified adjoining tubing..
Thank You .. :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby DasBaldGuy » Sat Mar 20, 2010 11:42 am
Tube Notcher
DasBaldGuy
Postby starleen2 » Sat Mar 20, 2010 11:47 am
DasBaldGuy wrote:Tube Notcher
Yep - that would be it! ;) :thumbsup:
starleen2
5th Teardrop Club
Postby Classic Finn » Sat Mar 20, 2010 11:47 am
Man that didnt take long.. Thank You ever so much.. That will most definitely help. :shake hands:
Now to see if I can find one here in the land of Reindeer, Million Saunas and 1.5 Teardrop Trailers :lol: ;)
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 20, 2010 11:52 am
Now to see if I can come up with the name in our language or languages. :lol: :lol: its a pain when you try to think of things in 3 or 4 languages at the same time. :? :D
Whats the price of them any ideas? :D
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 20, 2010 11:53 am
Thank You Also Scott :applause: :thumbsup:
Classic Finn
Images: 146
Postby DasBaldGuy » Sat Mar 20, 2010 11:54 am
Classic Finn wrote:Now to see if I can come up with the name in our language or languages. :lol: :lol: its a pain when you try to think of things in 3 or 4 languages at the same time. :? :D
Depends where you buy them....there are all kinds on the internet and some are "jigs" that use your existing Drill Press others are self-contained tools.
DasBaldGuy
Postby Classic Finn » Sat Mar 20, 2010 12:03 pm
Iver never used one but I shall give it a try.. as soon as I locate one.
:shake hands:
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 20, 2010 1:05 pm
Ok After a bit of searching I found a Finnish Forum that has this topic however to my surprise a guy had ordered one from Harbor Freight USA.
But ok if your into the Finnish Language (Which I Doubt) :lol: Its name is
(Viistekone) this took me to some heavy duty industrial machines.. too big of an investment for a roof rack :lol: :lol: :lol:
Im still looking ..
Classic Finn
Images: 146
Postby mikeschn » Sat Mar 20, 2010 1:55 pm
Classic Finn wrote:Ok After a bit of searching I found a Finnish Forum that has this topic however to my surprise a guy had ordered one from Harbor Freight USA.
Im still looking ..
As a master of Google, I'm sure you'll find something that works! :D
Postby afreegreek » Sat Mar 20, 2010 2:00 pm
Im still looking ..
you can use a hole saw and a portable electric drill. I've done it many times with good results. just drill the pilot hole through the pipe first and replace the drill bit in the hole saw with a 1/4" steel rod long enough to go all the way through the pipe. if the pipe is really thin you can use a hole saw made for tile with diamond grit rather than saw teeth.
afreegreek
Postby Classic Finn » Sat Mar 20, 2010 2:03 pm
Im still looking ..
Dont know about that Mike but I just need to translate a few things and then Im on the right track :lol: :lol: ;)
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 20, 2010 2:06 pm
Im still looking ..
I just took a look see in my tools and low n behold I just found my some hole cutter blades.. ;) :D
Im using 20mm aluminum tubing for a test run.. Maybe its strong enough to use for a rack.. if not I have some electrical conduit here too. :twisted:
Thank you for the info..
Classic Finn
Images: 146
Postby Classic Finn » Sat Mar 20, 2010 2:11 pm
Im still looking ..
Wow I just took a peek into your gallery and looks like your a pro in wood working. Very Nice Work youve done.
This is what caught my eye.. curious eye that is. ;)
Classic Finn
Images: 146
Postby bbbrt76 » Fri Mar 26, 2010 9:27 pm
If you are not going to be doing enough to warrant the purchase of a notcher check out this link for another technique using a chop saw
http://pirate4x4.com/forum/showthread.php?t=456800
bbbrt76
