Went into the hall of fame to have alook at the new TDs and when I clicked on Montana Tear to my surprise up comes the pictures of John Curtis TD.Hey thats my TD.
John
It's not that it is broken. It just sends you to the wrong target. It's what happens when you let anyone try and post in the Hall of Fame. Some would be better off letting someone else do it for them.Nathan N wrote:Somebody didn't post the correct links. Here are MadJack directions for the Hall of Fame:
http://www.mikenchell.com/forums/viewtopic.php?p=481032&highlight=hall+fame+link#481032
I had read several posts about these broken links. Mike has to go in and correct them. A quick search found this one instance of the same issue:
http://www.mikenchell.com/forums/viewtopic.php?p=278625&highlight=hall+fame+link#278625
You can post a PM to Mike letting him know which one is broken.
Personally I'd like to see an electing/voting situation to get ino the Hall of Fame....or at least have a Moderator validate that it is actually Hall of Fame quality.
DasBaldGuy wrote:Personally I'd like to see an electing/voting situation to get ino the Hall of Fame....or at least have a Moderator validate that it is actually Hall of Fame quality.
Some of the Hall of Fame links are old broken picassa or other image sites where the account is no longer active....and soome of the Tears are just projects/not finished.
I'd king of like the Hall of Fame to be truly what it's name implies....but I am a bit of a pureist.
SO because my TD isnt finished it shoudnt be in the hall of fame?
