Newbe Questions Frame & Floor
Postby streetrod23 » Fri Mar 26, 2010 8:18 pm
Hi I am building a 5x8 frame. I have access to 2x2 16 gauge square tube for the frame and would use 1/8 for tongue. Would this be adequate for a lighter tear. I noticed the HD trailers are using this gage in a c channel. I believe the tube would be even stronger.
What is the advantage/disadvantage over a 1x2 wood framed floor vs. just plywood with the existing metal frame braces? Is 5/8 plywood thick enough
PS what a great site
streetrod23
Images: 21
Postby sagebrush » Fri Mar 26, 2010 8:29 pm
I made my 4x8frame of 2x2 14 ga. with 2x2 1/8 for the a-frame tongue. Here is a link to LOTS of answers. http://www.angib.pwp.blueyonder.co.uk/t ... tear84.htm Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
Postby doug hodder » Fri Mar 26, 2010 10:28 pm
I've built a couple with 16Ga. sq. tube frames 4.5'x10's and a heavier tongue although it was a composite type tongue..... I also used a wood outer perimeter to attach the sides to under a 5/8" floor. Sides extend below the frame. It's a lot easier to have something to shoot screws into on the bottom of the sides to attach. The floor was bolted through some angle brackets on the frame using carriage bolts. Doug
