Hey Woodie guys
Hey Woodie guys
Postby Reddiver » Thu Apr 01, 2010 2:52 pm
OK is the trim around the perimeter of the sides typically 3/4 in or is planned to 5/8 or 1/2? I am talking about the exterior trim .
Reddiver
Images: 38
Postby davidrn » Thu Apr 01, 2010 5:46 pm
After completing the sides, and applying CPES and Spar varnish, I used 3/4" Pine boards for the side trim, and then painted them, with spar varnish over that. I had left over Baltic Birch, so I cut it into 3" strips and applied it on the top edge, covering the side trim, and the staples holding the roof down. Same finish treatment for the top trim.With 1/8" Baltic Birch, bending was easy, and I filled in any gaps with extra Spar Varnish. No leaks or lifting yet.
Suppose you were an idiot......and suppose you were a member of Congress.......But I repeat myself. Mark Twain
http://mysite.verizon.net/vze6oxyu/
davidrn
Images: 16
Postby boomboomtulum » Thu Apr 01, 2010 6:57 pm
I planed down to 5x8. 3/4 looked a little to bulky.
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby Woodbutcher » Thu Apr 01, 2010 9:15 pm
I used 1/2". for the roof line I laminated 1/8th" and glued and clamped it to a form I made to make the curve match my roof line.
Woodbutcher
Postby doug hodder » Thu Apr 01, 2010 10:01 pm
I resawed the 3/4 down to 3/8 and planed it. Doug
Postby afreegreek » Thu Apr 01, 2010 10:34 pm
5/16" to 3/8" if the trim will have a square or slightly rounded over profile and up to 1/2" for an edge treatment (depending on the treatment).. this is similar to a frame and panel door and what the "woodie" look is supposed to emulate..
this door is 1-1/4" thick with a 1/2" panel...
afreegreek
Postby Miriam C. » Thu Apr 01, 2010 10:36 pm
:thinking: I think I had the side trim planed to 3/8". The top is planed to 1/8. I used small brads to hold it in place until the epoxy set. I covered them with Epoxy then varnish.
Postby wannabefree » Thu Apr 01, 2010 11:09 pm
Mine is 1/2. It doesn't really matter how thick it is since it isn't structural. It just hides raw plywood edges and staples. So use whatever you want.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Reddiver » Fri Apr 02, 2010 12:10 pm
Once agin I thank you all I to think 3/4 just looks to thick.
Reddiver
Images: 38
