After sitting dormant for the last 6 mos I'm back to finishing this tear off. What kind of glue did you peeps use between layers on roof? Titebond III or Gorrilla Glue or Liquid Nails or ?
Gage wrote:Well if it's not flat, one sheet of 1/8" is strong enough, especially if your going to fiberglass over it. !/4" is over kill no mater what those who think they know everything tell you. Arne has done it both ways and I'll bet he has no regrets doing it the way he did it with his second build which is also bigger than his first.
Pizzaguy wrote: Thanks for your comments Gage, I really admire your work. I'll keep your opinion in mind if I build a 2nd one. But since this is how my plan is progressing I'll have to stick with the plan as is. I want to have a clean surface to keep that woody look w/ no fasteners exposed. And seeing as I used some screws & brads to mount the 1st layer I want to add a 2nd and glue it on w/ NO fasteners visible.
