Hi All,
New guy here needs opions of others for my build on axel options
My build will consist of a 5 ft X 10 ft TD and I'm leaning towards a modified Benroy design with offroad capibilites, much like the Outback Teardrop design.
I'll be using rims to match my 4Runner which are 265/70/17 with a 6-5.5 bolt pattern and hub to hub distance of 74 in on a 2x2 in. steel frame. I was convinced on using a 3500 lbs straight axel with leafs and electric brakes from Dexter but I'm second guessing myself if I should opt for the Torflex, I know they offer a smoother ride but don't know if they are good for off road use or have the height I'm looking for. any opions pro or against either is greatly appeciated.
