Will Vasaline inside a composit wall be ok?
Postby dh » Mon May 17, 2010 1:34 am
I'm running some wires inside my walls before I glue on the final skin and want to put something on them to keep them from getting glued to the wall. Will Vasaline hurt anyting if used inside the wall?
dh
Postby Miriam C. » Mon May 17, 2010 7:15 am
:thinking: Dunno. You can certainly use some clear tape. Just be sure you know where they are so you don't drill through them later........ :thumbsup:
Postby bobhenry » Mon May 17, 2010 7:26 am
The insulation sheathing on most all coated elctrical wire is oil and solvent resistant. I would not hesitate to use it. Another idea would be cooking spray or cooking oil. When large commercial buildings are done in conduit they use a pulling lube to allow the long runs and large bundles of wires to slide easily thru the conduit. I am certain it is similar in composition.
If you want the real stuff any electrical supply houe will have one of these brands.......
http://www.toolup.com/ideal/cable-pulling/cable-pulling-lube/
One thought is petrolatum is oil based and will continue to wick for a long while possibly soaking thru the wood fiber and affecting any interior finishes you try to apply if it is able to travel that far. KY jelly is water base and will evaporate in a few days. It is water base and water soluable for easy cleanup ..... and using up the leftovers could be great fun :roll:
Postby starleen2 » Mon May 17, 2010 7:57 am
bobhenry wrote: ..... and using up the leftovers could be great fun :roll:
:o :o
starleen2
5th Teardrop Club
Postby Arne » Mon May 17, 2010 8:15 am
why do you care if it gets glued to the wall?
I would not use anything that might get absorbed into the wood and keep the finish from sticking... it might migrate through the panel to the other side, but am not sure about that one.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby dh » Mon May 17, 2010 2:41 pm
The way they are running, if i leave a large tail out of the hole where they enter the celing, the wall will not be able to lay flat on the floor for gluing. I was going to coil up some extra in the larger switch opening and pull them out the top after wall is glued.
dh
Postby bobhenry » Tue May 18, 2010 8:03 am
dh wrote:The way they are running, if i leave a large tail out of the hole where they enter the celing, the wall will not be able to lay flat on the floor for gluing. I was going to coil up some extra in the larger switch opening and pull them out the top after wall is glued.
Just a thought .....
If you lay down new sheets of blue foam it will allow equal pressure on all areas and yet compress where there is a point load. When you pick up your wall there will be an imprint of the wires in the foam but the veneer side will have had the exact same pressure all over. It will also protect from small rocks and variations in the concrete. You can use the foam later in the roof so it will not be a waste.
Postby Shadow Catcher » Tue May 18, 2010 8:26 am
Oil/petroleum will attack rubber and some plastics. Silicone such as Armorall will not. You can also use dry lubes, heck I have even used dry antiperspirant
Postby dh » Tue May 18, 2010 9:50 pm
Hmm, I might have to think about that.
dh
Postby dh » Tue May 18, 2010 9:54 pm
Shadow Catcher wrote:Oil/petroleum will attack rubber and some plastics. Silicone such as Armorall will not. You can also use dry lubes, heck I have even used dry antiperspirant
Stick deoderant? Maybe it will keep the glue odors at bay :lol: :lol: :lol:
I might have to experiment with some dry lubes :thinking:
dh
Postby wannabefree » Tue May 18, 2010 9:56 pm
Why not use the stuff electricians use. It goes by various nicknames - slickum and gorilla snot is what I know it by. Get it at any big box in the electrical department. Comes in quart squeeze bottles and 5 gallon buckets. My guess is a quart will do :D
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Shadow Catcher » Wed May 19, 2010 6:48 am
dh
This was the spray on antiperspirant, leaves a white powder and it will not attack rubber. Talcum powder will also work, as will penetrant developer. I was having a very difficult time telling where an oil leak was coming from and picked up a can of developer from a welding supply place, it is basically talc in a can and used with visible and fluorescent dye penetrant testing.
Postby dh » Wed May 19, 2010 7:26 pm
Shadow Catcher wrote:dh
Dualy noted, I was starting to wonder about baby powder. Might spend more time this weekend experimenting on this than building a teardrop :lol:
dh
Postby Micro469 » Wed May 19, 2010 7:59 pm
wannabefree wrote:Why not use the stuff electricians use. It goes by various nicknames - slickum and gorilla snot is what I know it by. Get it at any big box in the electrical department. Comes in quart squeeze bottles and 5 gallon buckets. My guess is a quart will do :D
Have you ever tried to pull wire out of a conduit after electricians filled it with "gorilla snot"? They don't budge......... :thumbdown:
John
Micro469
Images: 382
