Floor and Wall Design Question
Postby J.Heyboer » Thu Jun 03, 2010 11:46 am
Hey Guys/Gals
I am just finishing up my trailer frame and am about to begin building the floor, and cutting my wall profiles.
On floor, if I am not planning on installing insulation, can I simply attach 3/4" ply directly to my frame? Is there a structural reason to have a frame of 1x2s under your floor? The pop camper I dissassembled for my frame was built this way.
The walls would be framed out of 1x2s with 1/8" ply on both sides. These would then sit directly on top of 3/4" ply floor.
Below is a pick of what I was thinking. What do you think?
J.Heyboer
Images: 84
Postby J.Heyboer » Thu Jun 03, 2010 11:49 am
Here is a pic of my trailer frame. It's 12' x 6'. Walls will be 5' ~ 6' high.
J.Heyboer
Images: 84
Postby madjack » Thu Jun 03, 2010 12:15 pm
J, I use 1/2 ply...only... for the floor, I do lay a piece of blue foam insulation on the floor, under the mattress...... 8)
Postby mikeschn » Thu Jun 03, 2010 3:41 pm
The only reason to have 1x2s or 2x2s under the plywood floor is to give you an easy way to attach the sidewalls to the floor.
Of course if you choose a different way to attach the sidewalls, then you wouldn't need the subfloor.
Postby madjack » Thu Jun 03, 2010 6:26 pm
I used 3/4 ply for the walls and used 1x1/16th AL angle(with gorilla glue and screws) as a cleat to attach floor/walls together...I used self-tapping trailer decking screws to attach everything to the trailer frame................
Postby dh » Thu Jun 03, 2010 8:59 pm
madjack wrote:J, I use 1/2 ply...only... for the floor, I do lay a piece of blue foam insulation on the floor, under the mattress...... 8)
Make sur its good 1/2" though. That 3 ply they have at HD well...
I found some nice 7 ply 1/2" for about $3.00 more a sheet.
dh
Postby J.Heyboer » Fri Jun 04, 2010 10:47 am
Thanks for the feedback Mike, Jack, & DH.
Jack,
Would you still recommend a 1/2" floor if it was going to get stood on? My wife and kids will be standing in it for sure if I make it between 5 and 6 feet tall.
John
J.Heyboer
Images: 84
Postby madjack » Fri Jun 04, 2010 1:17 pm
...NO, if you are going for standy height, go with 3/4 ply...RE: dh's advice about quality ply is spot on...I buy all my ply thru a cabinet shop and I am able to get birch veneer/poplar core 11ply 3/4 and 9 ply 1/2.........................
Postby DesertSkies » Fri Jun 11, 2010 4:34 pm
I'm looking at a 4x8 Benroy profile on a HF trailer. Is 3/4 wall and 1/2 floor the best way to go for this size? I haven't seen many with thinner walls. I'll be using spruce 1x2 for framing.
DesertSkies
Images: 49
