fender clearance
fender clearance
Postby norm's tear drop » Mon Jun 07, 2010 6:16 pm
Just got my fenders from rw johnson
was wondering how much top clearance i should leave at the top side
between tire and fender .don't want to hit a bump and rip the things off
thanks people
norm's tear drop
Images: 133
Postby caseydog » Mon Jun 07, 2010 6:38 pm
I went by what looked pleasing to my eyes. It is MORE than enough to keep the tires from hitting.
CD
My build journal is HERE
caseydog
Images: 515
Postby Gage » Mon Jun 07, 2010 6:44 pm
Do you really think your wheels will move up that much? You must have really soft springs and if that's the case, they are too soft. :thinking: Locate your fenders where they look good and right to you.
Image Image Image
Gage
Images: 28
Postby norm's tear drop » Mon Jun 07, 2010 6:50 pm
Thanks gage
no i dont think my springs are to loose but they are just one leaf spring but i was just wondering if there was a rule of thumb for such .look is were ill put it but if you had to guess would you say no closer than a 2 inch space would be good
norm
norm's tear drop
Images: 133
Postby Dirran » Mon Jun 07, 2010 8:49 pm
If it is a real concern, measure the distance between the top of the axle to the chassis rail and use that as the distance between the top of the tyre/tire and the mudguard.
Dirran
Images: 23
Postby 2bits » Mon Jun 07, 2010 11:35 pm
Hey Norm, Just answered your PM, but on mine I have really low clearance and drove throiugh some "interesting" angles and never had a rub. I would just center the fender around the tire and you will be good. Mine is actually below centered and just over 2 inches clearance.
Hey, Did you get your hatch all sorted out ok??? Thanks for saying hello! !!
Thomas
2bits
2bit Member
Postby madjack » Tue Jun 08, 2010 8:31 am
...measure the distance from the top of the axle to the frame...this is as much as it is possible for the axle to move under maximum deflection(major pothole/bump at high speed with max load onboard)...I would leave at least 3+ inches.................
Postby aggie79 » Tue Jun 08, 2010 8:49 am
Hi Norm,
It's good to hear from you. Thanks for posting this question. I'm about 1 month from installing my fenders and was wondering the same thing.
Postby madjack » Tue Jun 08, 2010 9:06 am
...something to try...take a small piece of 2x4 and place it on edge, across the tread of the tire, put the fender in place and take a look...adjust accordingly................................
