Sealing Doors
Sealing Doors
Postby XxXBDrockXxX » Tue Jun 08, 2010 6:23 pm
I'm having problems sealing my doors I put weather striping on there but it keeps coming off. Is there any other type of seal I can use?
XxXBDrockXxX
Postby Miriam C. » Tue Jun 08, 2010 6:27 pm
:o ;) I got tired of the weather strip coming off and epoxied it.... :twisted: There are other forms of striping that are not peal and stick. You can also look for something that staples on or a heavy duty. Also Auto applications. ;)
Postby wannabefree » Tue Jun 08, 2010 8:49 pm
I had that problem, too. Be careful not to stretch the weatherstripping at all or the tension will cause it to pull loose. I also went through several brands until I found one that stayed stuck. Unfortunately, I don't remember what brand I finished with. It's an age thing :)
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby parnold » Tue Jun 08, 2010 9:17 pm
I used weatherstripping without the glue tape, and used 3M weatherstrip adhesive. That's what they use to hold weatherstrip on cars. Actually the weatherstrip I bought was a 50 foot roll of automobile trunk weatherstipping,
parnold
Images: 302
Postby rladams39 » Fri Jun 11, 2010 6:28 pm
parnold wrote:I used weatherstripping without the glue tape, and used 3M weatherstrip adhesive. That's what they use to hold weatherstrip on cars. Actually the weatherstrip I bought was a 50 foot roll of automobile trunk weatherstipping,
parnold was the stuff you used the adhesive that is kind of a snot yellow color, and is kind of stringy like hot cheese?
If so that stuff is great. Works good for gluing leather together also.
rladams39
Images: 30
Postby parnold » Fri Jun 11, 2010 6:34 pm
3M Super Weatherstrip and Gasket Adhesive. Part # 08001.
Yes it is yellow, and when you're spreading it, it is sort of like melted velveeta cheese in it's consistency.
parnold
Images: 302
Postby Rigsby » Fri Jun 11, 2010 7:52 pm
If you have only got a small gap to seal, Run a bead of silicon sealer around the door, with the bead slightly bigger than the gap. Smear a bit of oil on the door jamb surface, or cover the jamb with some food clingfilm and oil that. So the silicon doesnt stick to the jamb
Close the door, and the squashed silicon will make a perfectly profiled seal. Open it again and remove the film
Now leave to dry
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
