The Rimple is finished
Postby Waliczek » Sat Jun 11, 2005 9:59 pm
Except for the mattress the Rimple is completed and ready for a road test. Thank you Andrew for the designs. Took a little less the 8 months. Had a ball building it.
http://pg.photos.yahoo.com/ph/wa1iczek/album?.dir=8c89
I hope this picture attempt works.
Tom[/url]
"Toys"--2003 Dodge Dakota--TT Rimple"Gypsy"--1955 Boles Aero Travel Trailer--2002 Sweetwater 20' Pontoon--1982 22' Mcgregor sailboat..
Waliczek
Postby RAYVILLIAN » Sat Jun 11, 2005 10:44 pm
The rimple looks great. Good job! :applause:
Are you going to try to get to Minden? If not' or if so, we have to try to get the MO/KAN tears together some where this summer.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby Waliczek » Sat Jun 11, 2005 11:30 pm
Thanks Gary for the kind words. Although I have had the Minden notice pinned on the wall since it came out, I had plans to try and go, however, Somethings just do not work out. I will not be going to this years gathering. However, I do like the idea of a local drag somewhere close by, say within a 100 miles or so. I will be alert to anything local that may come up. I do know that In August I will be using the trailer. I built the trailer in the first place to get away from having to sleep in a tent when I go to my yearly archeological (volunteer) dig. I really am too old to sleep and care for a tent. (67)- I plan on calling my trailer the Gypsy, Not very original, I Know, but if you happen to pass a rimple named Gypsy. Honk, It's only me.
Take care,
Waliczek
Postby GeorgeT » Sat Jun 11, 2005 11:49 pm
Great Job! Lotza work! I just finished mine except for mattresses too and it took 8 months also. Phew! I know it feels great. :applause: :thumbsup:
Just got my website up featurin' my camper.
http://home.earthlink.net/~g.teague/
Lookin' up in da skize with ize on da prize
GeorgeT
great looking rimple
Postby surveytech » Sun Jun 12, 2005 4:17 am
I am planning to build the rimple as well. Really like the design features of maximum space in the galley.
did you find that when complete its a bit heavy in the back? not enough tongue weight?
Post more pics when you can.
It looks awesome!
surveytech
Images: 6
Postby BobR » Sun Jun 12, 2005 5:40 am
George,
The trailer really looks great and congrats on getting your site up. I have one question...how did you construct and seal the angles on the roof and front?
Bob Richert
Parrish, FL
"Be glad of life because it gives you the chance to love and to work and to play and to look up at the stars"
BobR
Postby asianflava » Sun Jun 12, 2005 6:28 am
George, Congrats! I wish I could work as fast as you.
I was checking out your site and got to looking at your a/c unit. Is the plug still attached to the back? I took mine out so that the condensation can drain better. The bottom of my unit is designed as a tray to hold the condensation, with the plug removed, it will drain out the back before the tray overflows. Yours may be different but you may want to check into it.
asianflava
Postby Arne » Sun Jun 12, 2005 7:28 am
I like the drip-guard over the doors. Can anyone tell me where it is sold?
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby exminnesotaboy » Sun Jun 12, 2005 8:36 am
Tom,
Looks Great! Can't wait to check it out in person sometime.
Anthony
exminnesotaboy
Re: great looking rimple
Postby angib » Sun Jun 12, 2005 9:40 am
Tom, good work - I've updated my Hall of Fame!
surveytech wrote:did you find that when complete its a bit heavy in the back? not enough tongue weight?
I'd be interested to know the answer to this as well.
Andrew
angib
5000 Club
5000 Club
Images: 231
Re: The Rimple is finished
Postby BobR » Sun Jun 12, 2005 11:04 am
Waliczek wrote:Except for the mattress the Rimple is completed and ready for a road test. Thank you Andrew for the designs. Took a little less the 8 months. Had a ball building it.
Tom[/url]
Tom, Great job...I kept watching the Hall of Fame with no updates and all of the sudden you're done!! Enjoy your new masterpiece...
Bob Richert
Parrish, FL
BobR
Postby GeorgeT » Sun Jun 12, 2005 4:37 pm
George,
Thanks. The angle is 45 degrees. The framing underneath has pieces running all the way across the width of the trailer that I ripped on the table saw that is 45 degrees to match the angle. The front piece of plywood and the top piece of plywood were cut with a circular saw to match the angle also as they butt together. The narrow piece going all the way across was cut on the table saw to match the angles to match the butt joint. Then glued, stapled and screwed down. I sealed it with some metal I found at Home Depot. It's some really thin stuff that I believe is normally used to fit underneath the edge of the shingles on your roof called drip edge I believe. It comes white and easy to bend. It was originally a 90 degree angle but being so thin it was easy to conform it to the correct angle to get a good professional looking fit using a lot of pan head screws. An ample bead of silicone is underneath these pieces of metal as is all the metal on my camper. The pic shows the metal. Sorry I don't have a closer pic. ;)
GeorgeT
Postby GeorgeT » Sun Jun 12, 2005 4:42 pm
asianflava wrote:George, Congrats! I wish I could work as fast as you.
I moved my cord to around the side to get it out of the way of the slide in and slide out motion. Yes, I removed the plug. Have been running it for a few days and seems to be no problem with drainage. Trailer needs to be level though or it won't all drain out.
GeorgeT
Postby GeorgeT » Sun Jun 12, 2005 4:49 pm
arnereil wrote:I like the drip-guard over the doors. Can anyone tell me where it is sold?
I got my drip caps on line at this site. Go to hardware/molding trim/drip caps
http://www.crestviewrv.com/html2/PartsCat.html
GeorgeT
Postby bdosborn » Sun Jun 12, 2005 7:01 pm
Well done. I bet you can't wait to try it out.
Images: 806
