My head is spinning... I have read several threads now for constructing the wall using the sandwich technique but I have a few questions:
I notice that the outside wall extends past the frame to allow for the placement of the spars. Are two patterns being used to create the inside and outside walls? I was studying Mark's and Cindy's excellent Little Switerzland build photos to try and wrap my head around it.
What pattern is used to route the edge of the frame?
If one pattern is used, how do you compensate for the area between the top of roof and interior walls?
I purchased SF's guide but I am still confused on how to use patterns properly. I'm probably overthinking things, right?
Many thanks in advance.
Patrick
