Glue suggestion needed soon
Postby Larry C » Mon Jun 28, 2010 8:11 pm
I am ready to put the final 1/8" (bottom) skin on my sandwich floor.
I have PL Premium, but no where on the tube does it say anything about using it on blue foam. All my framing and ply has been epoxy coated. I decided not to use the PL to install the blue foam between my floor frame members because I was not sure of compatability. I opted for thickened epoxy which took much longer.
I am now ready for the final skin and would like to use the Pl but, I need to know if it will work. I have spent too much time sealing everything to destroy the insulation because I used the wrong adhesive.
I can use the epoxy again but I would rather use something quicker.
Has anyone used PL Premium with success in this application?
Thanks,
Larry
Larry C
Images: 78
Postby Ageless » Mon Jun 28, 2010 8:25 pm
Liquid Nails is safe to use with the foam
Ageless
Postby Miriam C. » Mon Jun 28, 2010 8:56 pm
If you screw it down any glue that will stick to the wood will work. You need not glue the foam....... ;)
Postby kennyrayandersen » Tue Jun 29, 2010 3:07 am
Miriam C. wrote:If you screw it down any glue that will stick to the wood will work. You need not glue the foam....... ;)
Gluing the foam to the plywood makes it a structural sandwich. :thinking:
kennyrayandersen
Images: 38
Postby Larry C » Tue Jun 29, 2010 9:33 am
I agree about the structural sandwich which is what I am building, the skin has to be glued to the entire surface, including the foam. Miriam, the floor is a structural part of my build. It will not be supported by a steel permeter frame, just an A frame tounge/axle.
What I really need to know is whether PL Premium is safe with Blue Foam?? Has anyone used it for this job?
Thanks for the suggestions
Larry C
Images: 78
Postby chorizon » Tue Jun 29, 2010 11:57 am
Larry C wrote: What I really need to know is whether PL Premium is safe with Blue Foam?? Has anyone used it for this job?
Yes, it is and I have.
However, I've found white woodworking glue to work better.
chorizon
Images: 94
