Quick question on sidewall and torsion axle
Postby Aint2Proud » Sun Jul 11, 2010 11:51 am
Ok my frame was done yesterday and I have already built the walls. This being my first teardrop build I missed the clearance for the torsion arm over the sidewall by about a 1/4 inch. My sidewall will cover the frame. I have a Flexride axle rated at 2000 lbs that was not derated at all. I estimate my frame to be about 300 lbs. and the tear to come in around 1000 lbs or less.
Question 1 - I see on the Southwest Wheel website that the arm will travel about 3 inches from unloaded to "bump". If I put the arms at 22 degrees I will gain about 2 inches of travel space for the arms. Is this enough since I will not come close to the weight limit of the axle? I estimate teh tear to be no more than 1300 lbs loaded down for travel.
Question 2 - I have three options:
1-carve out my sidewall for the torsion arm travel - I am not opposed to this, but don't know how to seal the bottom edge of the aluminum skin at the carve out.
2-I can raise the sidewall with 2x4 framing instead of 1x4. This in combination with the arm angle adjustment comes close to the 3 inch travel number, but leaves part of the frame of the trailer exposed. I think I am ok with this and am leaning this way.
3 - My axle is bolted the the frame right now so I coule verify that the positioning was correct. I can have a spacer put in between the bracket and the frame when it is welded. This is a close second as a choice.
The tongue on the trailer tongue that is adjustable so I can adjust my ride height of the trailer very easily.
I appreciate any thoughts or suggestions. Thank you.
Aint2Proud
Images: 77
Postby aggie79 » Sun Jul 11, 2010 5:49 pm
I had the same situation as you, but myDexter axle is not adjustable on it. So, I went with your first option in question #2. I don't have a better picture, but you can see the notch in this photo:
Postby kennyrayandersen » Sun Jul 11, 2010 7:50 pm
Looks pretty good :thumbsup:
kennyrayandersen
Images: 38
Postby john » Mon Jul 12, 2010 5:55 pm
I have the same axles you do and chose the carve out method. I painted, though, and did not have the problem with the aluminum you described.
Perhaps you can seal the area with a couple of coats of epoxy before covering with the aluminum. If not epoxy, I think, the evil black stuff many of us choose to coat the bottom of our tears would work well.
I doesn't have to be pretty, as will not be seen.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
