solution to hatch opener
Postby timlsalem » Fri Jul 16, 2010 12:11 pm
this is my solution to keeping my galley hatch opened and to keep the wind from blowing it closed. I'll cut them to size and insert a spring inside the bottom part that is too weak to spring it open but strong enough to assist in opening.
KIA'S--MIA'S--POW'S--DAV'S--are what our freedom cost us
timlsalem
Images: 40
Postby john » Fri Jul 16, 2010 4:35 pm
Could you explain a little more? Was it an collapsible paint stick?
Here is my solution.
My hatch is very light so no assist is needed.
But I wanted a support that would hold it up, lock automatically when opening, and not unlock (allowing the hatch to fall) if the wind were to remove the weight while the hatch is open.
Link to Youtube video:
http://www.youtube.com/watch?v=unMNp4f_BME
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby timlsalem » Fri Jul 16, 2010 5:11 pm
John: yes they are paint extender poles. The inner pipe is smaller then the outside one and has a twist knob that tightens against the inner tube. I plan to cut them down to what I want my hatch to open to and fasten them to my walls. After they are cut I will experiment with springs to make opening the hatch not so laborous. I haven't skinned the inside of the hatch yet and right now I would guess it weighs maybe 30 #. It will probably double that after skinned.
timlsalem
Images: 40
