Sandwich insulation thickness VS wood thickness
Postby tcolar » Sat Aug 07, 2010 2:48 pm
So 1x2 are like .75 thick whereas 1'' insulation is ... 1''
so how do you deal with that (not flat) ... i would guess leaving the gap would remove a lot of the strength of the sandwich
Thanks.
tcolar
Images: 15
Postby Ageless » Sat Aug 07, 2010 2:58 pm
Foamboard is made 1/2", 3/4" and 1"
Ageless
Postby tcolar » Sat Aug 07, 2010 7:40 pm
They have those sizes for the white foam -rtech - buut is that good for a sandwich ?
The rigid foam -pink- is avail in 1 1/2 I guess that would work with a 2'' wood, kinda spendy though.
tcolar
Images: 15
Postby tcolar » Sun Aug 08, 2010 1:05 am
So the big box stores have rtech in 3/4 but that kinda foam is kinda messy and doesn't feel like it would be that good structurally.
HD has pink foam in 1 1/2 which would work although that makes for kinda thick walls.
Can blue/pink foam be bought in 3/4 somewhere ?
tcolar
Images: 15
Postby aggie79 » Sun Aug 08, 2010 7:46 am
I used the "white" insulation. It is a little messy, but works well. The "blue" and the "pink" are available in 3/4" thicknesses in our area. The reason I chose "white" over the others is that the white compresses more. Insulation tends to run wild on thickness - usually slightly greater than 3/4" - but the "white" compressed nicely to fit between the 3/4" framing.
I glued my foam too, but the majority of the strength of a stressed panel or torsion box is in the skin.
Postby tcolar » Sun Aug 08, 2010 9:30 am
On the white stuff did you remove the plastic film or nit ? Did you use special foam glue ?
tcolar
Images: 15
Postby john » Sun Aug 08, 2010 10:01 am
I ripped 1/2" plywood on the table saw for my (battens?) studs -- the spacers between the skins of a built-up wall.
Advantages:
--It was cheaper than the 1x3's as one piece of $12 plywood would make around twenty 1/2"x2" studs each 8 feet long. That is 160' of length. So one piece of plywood could have provided me with all the studs I needed.
--I used two sheets of plywood, though, because of another advantage -- I could cut the studs to the width I needed. In some places like along curves I found additional width useful. In other places I used the extra width to create a skirt along the sides of the camper or as extra support for the fenders.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby planovet » Sun Aug 08, 2010 12:04 pm
I used all three...blue, pink and white. Don't ask me why but it just worked out that way. One was thinner than the others but I can't remember which one. I did not glue mine, just wedged it in between the studs. The walls will hold it in place and no noice if you have a tight fit. And yes, I removed the plastic film.
ImageMark (& Cindi)
planovet
The Cat Man
Postby aggie79 » Sun Aug 08, 2010 6:43 pm
tcolar wrote:On the white stuff did you remove the plastic film or nit ? Did you use special foam glue ?
I removed the plastic skin and the mylar foil. As far as glue, I used PL Premium - just a few dabs.
Postby Cliffmeister2000 » Sun Aug 08, 2010 6:51 pm
I used the white stuff. Didn't remove the skin. It worked great. I remember seeing a post where somebody ran the pink stuff through a surface planer.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby john » Sun Aug 08, 2010 7:12 pm
Do you not have 1/2" insulation available at Lowes or HD?
I turned the foil to the outside to aid in reflecting heat. I have found it is easier to heat the camper than to cool it, so reflecting the heat away when I want to cool it is the best way to go for me.
I did not find it necessary to glue anything to the insulation. It just rides inside the wall.... insulating.
The studs, ply sandwich, and things like cabinets, walls for bathrooms, and benches add more strength than expected.
Penomeli ikibobo
john
john
Images: 261
Postby kennyrayandersen » Mon Aug 09, 2010 10:23 am
It's best if the foam is glued to the facesheets (skins) since that is how the outer skins become effective together. Without the foam reacting the shear the facesheets both act independently (not bearly as strong). In that case, it makes sense to remove any kind of coating or plastic that would prevent the foam from sticking to the skins.
You can also plane the wood to match the foam. It also appears that there are some insulation companies that make the foam in big blocks that can be custom cut, but I haven't figured out how expensive they are.
kennyrayandersen
Images: 38
Postby Nobody » Tue Aug 10, 2010 9:12 am
When I built my TD in 2006 I had no problem finding appropriate thicknesses of 'closed cell' foam board locally. We have a large HD within 3mi & a new Lowes approx 6mi away. Both had a selection of the pink (Owens-Corning) & blue (Dow) from 1/2" to 1 1/2". I used 1" under the floor, 3/4" in the walls & two layers of 3/4" in the top/front. Since my spars are approx 1 1/2" square (ripped 2x4's) the two layers worked better on the curves & I only had to 'kerf' the foam in a few places for proper fit. A few pix -
Harvey -
Nobody
Images: 342
Postby john » Tue Aug 10, 2010 10:34 am
I live in NC, but within 5 miles of the VA. state line.
The NC Lowes/HD had different selections of foam board than the lowes/hd in VA.
VA. had thicker stuff than NC.
Penomeli ikibobo
john
john
Images: 261
Postby kennyrayandersen » Wed Aug 11, 2010 1:49 am
you can even get on-line and check the inventory. What you will find is that it varies by store location and also region. Down south, it's hard to get the 2 inch thick stuff -- most of it is 3/4 or 1 inch. They may be able to order stuff in, but usually they want you to order a lot of stuff (like a full pallet).
kennyrayandersen
Images: 38
