spare tire mount
spare tire mount
Postby mobile camper » Sun Aug 08, 2010 12:53 pm
My wife likes the way the spare tire was mounted on the back of Marjorie Forbs (RV Crazy video) teardrop. The spare tire was mounted on the back of the trailer and would sing out of the way and turn to be used as a table. Does anyone know how this was made?
Steve G
mobile camper
Images: 122
Postby bobhenry » Sun Aug 08, 2010 1:01 pm
Her husband and son fabricated it. I have some good clear shots it looks pretty straight forward.
Postby Ron Dickey » Sun Sep 05, 2010 7:14 pm
the above is the best I have seen just thought you would like to see further talk about the subject and see what others have done.
If you have the tools and know how I would do as above.
I wanted to do that but have little welding skills so I ended up making a fold down table that rides in the back and can fold out on ither side. depending on which side food prep was being done on. I have no galley.
Others came up with other ideas of how to make one from parts already made.
see
http://tnttt.com/viewtopic.php?t=30874
Here you will find more about the above unit and what others thought.
when I researched it I looked at swing out tire mouints for 4x4 units.
I found it to heavy for a wood mount and to time consuming to unbolt from a wood frame to swing out. If you do it do it in metel as seen above.
I get exsited every time I see them.
the 4th picture down I found to be the key to making sure that it does not fall down when opening.
My swing out wood table is supported by a chain that is attached at the top side of the trailer and it still needs that extra support seen in picture 4.
Ron
173882......173887
Ron Dickey
Images: 787
Postby Guntr » Fri Sep 10, 2010 6:32 pm
This is the most ingenious idea I have ever seen! I was tempted to build a TD or TTT when my current renovation is done, but this has me convinced me that I must just so I can use this great idea.
Not so tiny, but a lot of work: http://mytraveltrailerrestoration.blogspot.com/
Guntr
Postby LDK » Sat Sep 11, 2010 10:47 pm
Thats pretty slick how the spare tire turns into a table. I've seen these trailer pics before awhile back.
Larry
LDK
Postby Gage » Sun Sep 12, 2010 12:07 am
Aw, someone got some pictures off my web site. ;) No problem, glad they're being put to good use. And by the way, it was only her son who came up with that design as well as restore her Benroy for her. :thumbsup:
And as a side note. The car and teardrop is for sale.
Image Image Image
Gage
Images: 28
Postby mobile camper » Sun Sep 12, 2010 11:07 am
Does anyone know how to get in touch with her son, :worship: that he might lend some assistance with more pictures.
I think his idea is awsome and I would like to copy his design for my teardrop.
Steve G
mobile camper
Images: 122
Postby cuyeda » Sun Sep 12, 2010 10:27 pm
Another picture someone else posted for your research.
Cliff & Vanessa
cuyeda
Postby Gage » Sun Sep 12, 2010 11:46 pm
mobile camper wrote:Does anyone know how to get in touch with her son, :worship: that he might lend some assistance with more pictures.
Steve G
What more do you need? The pictures tell all. As for the dims, just make a mockup of what you feel is right. Every teardrop and frame is different. Besides Margie's son is into Hotrods, not teardrops and most likely doesn't have any plans tucked away. Probably just sketched it up and then fabricated it. ;)
Image Image Image
Gage
Images: 28
Postby Larwyn » Mon Sep 13, 2010 8:03 am
Steve G
Right, it was probably sketched on top of the welding table with soapstone. In my shop, as the project takes shape, the drawing fades and wears away, which is a good thing because there is sometimes not much resemblance between the two in the end anyway. That's the way most of my welding projects are done. Some are based on photographs, some simply to accomplish a goal with no earthly idea what the item will look like until it is finished. Many are never drawn at all. Very seldom do I want to build anything exactly as it was built by someone else.
Most of the dimensions on that spare tire rack would vary based on the width, ground clearance, tire size, etc of the trailer on which it would be mounted. I don't see much call for plans there, the pictures tell it all.
Plans? We don't need no stinkin' plans...... :lol: :thumbsup:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
