hinges????
hinges????
Postby igofshn » Tue Jun 28, 2005 12:37 am
Im going to order my hinges tomorrow and was wondering if I should get the same for the doors and hatch? Where is the best place to get them?
Thanks.
igofshn
Postby asianflava » Tue Jun 28, 2005 5:13 am
I got mine from Lil Bear. The galley and hatch hinges are different.
asianflava
Postby madjack » Tue Jun 28, 2005 7:44 am
...get the "hurricane" hinge for your galley hatch from Grant at L'il Bear...your door hinge will depend on how you build your door...a piano hinge of some sort, either flat or offset will be what you are looking for
Postby norm perkiss » Tue Jun 28, 2005 8:34 am
igofhn,
Austin Hardware has a wide selection on hinges.
http://www.austinhardware.com/
I purchased an aluminum hinge for the doors from Austin. (shipping was almost as much as the hinge) The hatch hinge from Lil'Bear. Get the hatch hinge a little longer than the width of the hatch as this will help divert rain from entering the galley.
Norm
norm perkiss
Images: 62
Postby igofshn » Tue Jun 28, 2005 9:52 am
Thanks for the info.
igofshn
Postby igofshn » Tue Jun 28, 2005 10:50 am
madjack wrote:...get the "hurricane" hinge for your galley hatch from Grant at L'il Bear...your door hinge will depend on how you build your door...a piano hinge of some sort, either flat or offset will be what you are looking for
Speaking of doors. I have my walls made out of 1/2 ply wood and ripped in half 2x4's with 1/8 luan inside. They are stuffed with 1 1/2 foam insulation. Should I make the doors the same or make them a little thinner?
igofshn
Postby norm perkiss » Wed Jun 29, 2005 9:05 pm
igofshn,
What ever works is the rule of thumb. My doors, per Kuffel Creek, are the same as the sides. Built just like yours. I saw a post about someone's doors warping when just 1/2' plywood was used.
You will need to off set by about 1/4" to allow for weather stripping around the door. Denny Unfried's web site has a good detail shot of the door.
http://www.uncledennyscorner.com/teardr ... pacer.html
Norm
norm perkiss
Images: 62
Postby norm perkiss » Wed Jun 29, 2005 9:07 pm
Oops, that is 1/8" off set, not 1/4".[/i]
norm perkiss
Images: 62
