I have a question I'm hoping you may be able to help me out with.
I bought three black camper windows, brand new, for my TTT.
For the front window, a large crank out, I drilled holes into the rim on 4" centers to mount with screws from the outside.
The two door windows, much smaller sliders, have a gasket around the inside and drilling holes to mount them from outside would cut into that gasket, (the gasket spans the entire width of the lip inside). I did buy the mounting rings for them when I bought the windows so I have them on hand.
I'm assuming that the wise decision would be to mount the door windows with the ring and not drill through the gasket.
I'll be using butyl tape for the front window before I mount it. Should I use the butyl tape over/with the gasket on the door windows, or just secure them with the ring and put a bead of caulk around it, inside and out?
I'm hoping to mount them this afternoon so any assistance would be greatly appreciated.
As always, thanks for all your help. I do appreciate it.
Brian
