Need sliding window
Need sliding window
Postby scaramoche » Thu Dec 16, 2010 4:24 pm
Hey folks
I need help finding a sliding window for the side of my TD. im looking for a sliding window i can install on the side of my TD. my wall's width are 3/4 inch, so i suppose they cant be thicker than that(or if they are how you construct around that), im looking for dimensions between 12x 12 inch and 24 and 24 inch but open am a bit flexable. can you guys give me links to anything? also rectangular are fine(probably what i need)
thanks
scaramoche
Images: 7
Postby parnold » Thu Dec 16, 2010 4:45 pm
I bought a used RV sliding window on Ebay. Price was fairly reasonable. I'd check out that as it requires no driving. :)
parnold
Images: 302
Postby grant whipp » Fri Dec 17, 2010 1:21 pm
Do you want mitered corners (square) or radius corners (rounded)?
I have radius corner slider windows in sizes 11x18, 14x21, and 14x24 ... all with clamp-rings for 3/4" walls. check out my website, www.LilBear.teardrops.net/parts.html ... and I'm in Redding, CA (sounds like you are in Sacramento?)
If you are in Sacramento, there is also that RV Dr. guy over behind Cardo, Ind. on West El Camino, for good used windows. Good Luck, and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
