Building Question - Walls
Postby Classic Finn » Tue Feb 15, 2011 2:58 pm
Evening from Finland folks.
Ive been thinking of using 3/4 inch walls on the Kit. Does this make any sense or should I stay with the 1/2 inch walls? Is this overkill?
If so can I obtain T moulding for the doors in 3/4 inch ?
Thanks ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby TPMcGinty » Tue Feb 15, 2011 3:02 pm
I got my door T molding from Grant:
http://www.lilbear.teardrops.net/parts.html#molding
My door is 3/4 inch.
Tim
TPMcGinty
Images: 146
Postby cracker39 » Wed Feb 16, 2011 3:12 pm
I think some TDers make solid plywood walls and some sandwich construction. I'm a fan of the sandwich wall as it's lighter and, if constructed correctly, just as rigid. And, I put 3/4' foam insulation between the 1/4" skin and 3/16" paneling in my side walls. The ends and top have 1 1/2" spars and get two layers of the foam as the roof and upper end panels get more sun and heat penetration.
Dale
cracker39
Images: 233
