GeoDrop wrote:I'm abandoning my current plans of using a wood veneer on my roof after a disaster with the hatch. (Operator error, not veneer error)
I'm strongly considering going with a fiberglass cloth over the entire roof/hatch and using a tinted epoxy to get the color I want. The initial wet out would be un-tinted but subsequent would be tinted a tan. I've found some epoxy pigment from US Compsites. Seal the epoxy with a varnish for UV protection. Raka has various weights of fiberglass cloth. I'm thinking this will be the best approach... but a few questions.
Questions:
1) Any flaws with this plan?
2) Any thoughts on the weight of the cloth? I'm thinking 6oz... my only other option is a 12oz given my width of 62+ inches.
3) Will fiberglass/epoxy mask minor imperfections in the surface?
Aluminum is out. I've considered vinyl but hard to find in wider widths and right color. EPDM sounds interesting but only white or black in the wider widths. Mildly concerned about imperfections telegraphing through.
http://www.uscomposites.com/pigments.htmlAppreciate input...
I think your on the right track glassing the whole top. Glass will help prevent
seams from opening, allowing water to seep in.
After building several strip built kayaks and canoes, I feel the best glass is tight weave 3.25oz rather than plain weave 4 or 6 oz.. It is a little slower to wet out, but requires much less epoxy, and you can get by with just one fill coat. An extra layer can be use for more structural strength if needed.
Don't be concerned about glass width, as long as you overlap seams 2-3" you can use narrow glass, and use as many pieces as you want. For your application you don't need a continuous piece of glass, just use seams and carry on. If you use the 3.25 oz. glass (Raka and others) the seams won't show at all, and won't require a lot of epoxy to hide.
I would advise against the pigment. from my experience, pigments are not opaque, just translucent. If you want color, consider one of the quality marine paints. They flow on and self level, just like it's sprayed on. Also, epoxy pigment weakens the epoxy.
The marine industry has had a lot of time perfecting these coatings (marine paints) to handle the most severe conditions. I was really impressed the first time I tried marine paint. Plus, marine paints offer great UV protection.
The smoother you make the surface before glassing will make the final finish that much better. I would only fill with epoxy/micro balloons mixture, epoxy won't adhere to most other wood fillers. Epoxy fill coats must be applied evenly, with drips and runs scraped off flush with the surface.
Final epoxy sanding should show just a dull surface with no shiny spots showing. Shiny spots mean low areas that the sanding didn't level. Another (thin) round of epoxy fill may be necessary.
Also, too much sanding will cause you to cut into the glass which will leave a sparkling surface in some light situations, but that's not as much an issue if your painting, and not finishing bright (natural wood)
Good luck, and let us know how it's going.
Larry C
