Any help, advise, or comment appreciated.
I suppose a belt sander could be attached also for a "table sander".
Anyway, let me know.
azmotoman wrote:Oh yeah! The Black and Decker or HF vise table/saw horse works really well for such things. I have used it as a table for my router. Opened the jaws, invert the router, clamp it between the plastic jaw inserts and turn out small pieces of trim that I would not otherwise be able to handle.
Nice for turning out trivets, trim or the small legs I made for our set of barrister cases.
It would do the same with a sander or circular saw.
Of course, mine is the HF brand. ( http://www.harborfreight.com/folding-clamping-workbench-with-movable-pegs-47844.html )
bobhenry wrote:I had to make several long rips in large flat stock while building Chubby and I found 2 padded "C" clamps and the extruded channel off of one side of an old aluminum storm door made a great straight edge. The lexan I cut for the roof would have been all but impossible to rip without this guide. I simply clamped it in place allowing the 1 1/2" offset of my saw and cut as normal.
However this setup will not allow you to mill 2x4 into 2x2 and such. Then the table saw will shine.
