I was thinking about 1/2" thick plywood with 1"x3" (on edge) cross members. 1x3 are very light and if they are close enough together they would make the 1/2" ply, solid.GPW wrote:Actually , I never heard of anybody falling through the floor on their TDs ... Not yet anyway ... Don't believe all that bracing/reinforcement is really necessary at all , just the way it was done in the old days where the structural wood WAS the Trailer frame ...
I don't think there is right or wrong. My particular desire is to build the tallest trailer I can to fit in my garage. If I can lower the floor by inches that gives me more internal height. I am also extending my floor width wise beyond the trailer frame. I will of course because of this be making some sort of framing. I just was thinking the framing could be at the same level as the trailer framing.chorizon wrote:I built a frame under my floor so that I could have something for my walls to screw into. I suppose I could have done it differently, though.
GPW wrote:Sure would !!! I totally agree with you about using the bracing/framing upright ... Twice as thick is 8 times as Strong !!![]()
Just as a thought , it would be much easier to drill upright 2"X4" s for the longer attachment bolts ...1"X3" would require a jig of sorts to do those holes through the somewhat narrow (3/4" ) width ...
Just as a concession to easier fabrication ... and the little extra weight is down low on the frame anyway ... Don't figure many TD'rs are really going for ultra lightness ... that with all the extra "stuff" they carry along ...
Easy , if not a bit pricy to just have some "wings" added to the steel trailer (welding/fab) Then you could bolt the floor directly to the steel for the Lowest height ... sometimes , fitting it in the Garage , inches count .... as I found out the hard way on my Big TD ..
You are doing some nice fabrication there on your trailer. I had a look. Have you added a water tank and pump?chorizon wrote:I built a frame under my floor so that I could have something for my walls to screw into. I suppose I could have done it differently, though.
absolutsnwbrdr wrote:There no one way that is correct. Everyone does it different.
I skipped the dimensional lumber frame under the 3/4" plywood floor. I made recesses for the frame bolts in the underside of the plywood floor. My walls and floor have absolutely no interaction.
Then my 3/4" uninsulated plywood walls bolt directly to the outside of the metal frame rails. You can barely see the few bolts along the bottom edge, but I countersunk the holes, filled them in after they were tight, and sanded them smooth.
StandUpGuy wrote:Seems like you have done it in a very sturdy direct way. I like it. In my situation the floor will extend out past the metal frame about 8" so I must frame in some fashion.
Drilling for the bolt heads as you have done could be hard to locate. did you put chalk on the bolt heads or something, to get a location?
Good idea with the hammering. I will do that too!absolutsnwbrdr wrote:StandUpGuy wrote:Seems like you have done it in a very sturdy direct way. I like it. In my situation the floor will extend out past the metal frame about 8" so I must frame in some fashion.
Yeah that overhang would require a different approach. To locate the bolt heads, I just placed the plywood on the trailer and whacked it with a hammer at each bolt location to leave a slight impression. I measured between those imprints to be sure, then started drilling.
