Hi all--
Work on my chassis is progressing! The frame and cross members are done, I'm welding on the tongue today, and I've mounted the axle sort of. I say "sort of" because I have the axle seat and the front and rear spring hangers welded on and the axle bolted up loosely, but nothing is tightened yet.
I'm using an Alko 2K# straight axle, mounted underslung.
Looking at it is sketching me out though. First, the U-bolt nuts came without lock washers and I wonder how tight they'll stay. Can anyone offer some reassurance about that, or should I go and buy lock washers anyway?
Second, I realize now how the springs flex in the rear hanger and shackle, and I'm freaked out about the nuts loosening as the bolts rotate slightly in the hanger and shackles. What keeps them from loosening?! The bolts are splined, so I can see how they move "with" the shackles, but what about the nuts? Why don't they loosen as the shackle moves back and forth and the bolts twist slightly in response?
--Mike C.
