Woodbutcher wrote:I won't use a porch light on my next build. All it does is draw bugs to your door if you choose to leave the light on to help find your trailer at night. If you want to use it to see a bear eating your cooler, wire it to an inside switch.
cuyeda wrote:Woodbutcher wrote:I won't use a porch light on my next build. All it does is draw bugs to your door if you choose to leave the light on to help find your trailer at night. If you want to use it to see a bear eating your cooler, wire it to an inside switch.
Good point! Didn't think of that! An alternative is a small pathway light down low under the door way to light the ground beneath the door. Not to bright, so the neighbors won't mind, and still find your way back from a bathroom run in the dark!
